Hi all,
If the price is same, which drive is better??
all 8X+-R ....
"NEC 2500A"
"Ricoh MP5308D"
"HP420i"
thanks...
I think the 420i is a rebadged NEC2500A. They're taking the 420i and cloning it and using it on the NEC2500 for the added bitsetting capability.
Here's the database and user comments:
http://www.dvdrhelp.com/dvdwriters.p...&Search=Search
thanks.....
but... the HP homepage show this 420i only support CD-R at 24X burning speed.... and the 2500a is 32X.. why??
and is it the Ricoh MP5308D also NEC 2500A OEM??
thanks.
HP dvd420i that shows up as a 420n is a rebadged ND-2500A. I think they only specify 24x/10x CD-R/RW speed because BenQ/Philips might take over the production later and their drives currently only support 24x/10x. From what I read the dvd420n is really 32x/16x CD-R/RW though. The HP drive burns DVD+R as DVD-ROM by default and supports changing book type on DVD+RW.
Ricoh MP5308D is a rebadged NEC ND-2500A too. It has not been confirmed whether it supports bitsetting/changing of book type or not.
There is also a patched firmware for the ND-2500A out which is based on the HP 420n and therefore supports bitsetting.
So if you don't mind flashing hacked firmware go with the NEC and you can use either HPs or NEC's firmware, but probably not vise versa.
"Live" picture effect - pictures end up "filmized"
By ANOther1676 in forum Software PlayingReplies: 10Last Post: 14th Oct 2011, 11:59 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 05:45
