Are there any DVD players that allow you to go forward or backward by frames while the movie is paused? I need to take screenshots during specific moments and VLC tends to pause several seconds after I hit the button.
Thread: Frame by frame DVD viewing
QuickTime with the MPEG 2 option can play VOBs and be moved forward or back incrementally. With QuickTime Pro you can also export the displayed frame as a still image.
I think what you want is either DVD Capture or maybe Capture Me. They are both helper applications for DVD Player, which I believe has a frame-by-frame navigation function.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
I have QT with an MPEG 2 codec, but when I try to load the VOB it says it's a file that QT doesn't understand. It has a VLC icon too.Originally Posted by Frobozz
On my non-copyprotected DVD I control-clicked on a VOB and chose open with Quicktime Player. It worked fine and I didn't even rip it to the hard drive. In fact, it said the default was Quicktime.
How do I debug/extract i-frame p-frame and b-frame?
By jwbrasil2 in forum ProgrammingReplies: 0Last Post: 20th Nov 2011, 12:24 -
Viewing YV12 images and videos, cutting a frame
By Festivas in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2010, 05:51 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
Frame by frame dvd player
By IllusionOfLife in forum Software PlayingReplies: 9Last Post: 2nd Nov 2009, 16:29 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 22:53
