Hi all,
I can't seem to capture from my camcorder entire video, which is 35mins . It cuts off at 4,194,211KB
I try the following settings, yet no can do:
type-2 avi
discontinuity (0)
max avi (1000000)
every frame (1)
I tried, So I can join them
type-2 avi
discontinuity (5)
max avi (22500)
every frame (1)
If there is a file size limit because of win98. The question I ask myself is, "How come I can rip or copy 10gig files?"
I'm using windows98 se,
Camcorder, HandyCam Video8 Trv-22 ntsc
Capturing device, ADVC-50
HD 80gigs
Thread: WinDV file size capture
Interesting, so my Handycam causes a restriction on file size.
Another problem I been having is when I join 4 files with virtualdub I get this error message " Cannot seek within file " countryscene" The parameter is incorrect"
I tried these methods mentioned at:
http://www.dvdrhelp.com/forum/viewto...ight=seek+file
But I still get an error, I scan the file and have no bad frames, I even renamed them, I placed them in a different directory. I still get this error message.
You guys have any idea on what I'm doing wrong or what I maybe missing?
thanks
It's not your camcorder, it's your file system. FAT32 has an absolute 4GB file size limit. If you want larger files, you need Windows XP or 2000 with NTFSOriginally Posted by thesnow
Interrupted WinDV Capture...Now I can't play the AVI file.
By ione in forum CapturingReplies: 11Last Post: 18th Oct 2009, 08:52 -
Size of Capture file
By gasport in forum Newbie / General discussionsReplies: 2Last Post: 23rd Sep 2009, 15:46 -
Smaller file size after Video Capture (help)
By convoy71 in forum CapturingReplies: 4Last Post: 4th Apr 2009, 17:05 -
Skipping in beginning of WinDV capture
By rjack in forum CapturingReplies: 1Last Post: 10th Jan 2009, 22:16 -
lower file size for a capture
By matneaves in forum Video ConversionReplies: 6Last Post: 1st Sep 2007, 11:34
Statistics
Newest guides
Latest tool updates
New media comments
