I've just bought and installed VDCEasy on Windows 2000pro, on which I've also got Matrox 2000 and Premiere 6.0. My CDwriter is a Sony CD-RW CRX160E SCSI. I cannot get the system to complete a VCD. It halts and warns "May have a bad driver in the CD writer/reader settings page." I've tried again with all combinations of the drivers on their drop-down box, and still no go. I"m also getting a yellow warning signb on "initializing 0.7.12 cygwin 1686 libvcd". I tried uninstalling and reinstalling VCDEasy, and no change. I've also deleted all versions of cygwin.dll except for the latest version, and copied that to C:\WINNT. Please help. I've had to duplicate this here because I'm getting no response on VCD authoring.
Thread: VCDeasy burning problem
Hi!
You didn't say which version of VCDEasy, but I'm assuming that you're using the latest 2.0.1.
Hmm, I also had problem with burning directly from VCDEasy and got the same error message as you. The problem was solved when I changed to "general-mmc-raw" in the CD-Writer settings. However, It appears as if you have already tried every choice in the drop down list in CD-Writer settings, with no luck.It halts and warns "May have a bad driver in the CD writer/reader settings page." I've tried again with all combinations of the drivers on their drop-down box, and still no go
If you're using VCDEasy 2.0.1, you don't need any ASPI-driver anymore. Instead, use the SPTI. If the version is 1.1.x, then make sure that the ASPI-driver are workning properly. Check at the bottom of the program.
If your ASPI-drivers are correct and working or if you're using the new SPTI in VCDEasy, then you should try the follwing thing.
Select the "CD Image File Recorder" as CD-Writer and create the bin-file. After that you burn your bin-file to a CD using Nero or some other burning software.
// Znooky
Problem with burning.
By googoodolls in forum DVD & Blu-ray WritersReplies: 7Last Post: 12th Dec 2009, 06:20 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17 -
Burning tracking problem or software problem???
By yogart in forum Authoring (DVD)Replies: 2Last Post: 24th May 2007, 12:39
Statistics
Newest guides
Latest tool updates
New media comments
