I thought it might have to do with the way it was encoded, but movies play full widescreen when I tried it in the my PS2, friend's DVD player, and my computer with PowerDVD. I made sure in the setup preferences that display was set to wide and TV type as NTSC. Never had a problem with hundreds of SVCDs and VCDs playing widescreen on this APEX 1500. But, only with DVDRs. Anyone know a workaround?
I have an apex 1500 and it plays anamorphic ntsc movies(wide screen) but not pal,plays them stretched,Maybe thats your problem?
Ben Johnson-I didnt take any stereos!
Thanks...but I don't think that's it. For example, I just converted a DivX to DVD using TMPGEnc and made sure the setting was NTSC and while it shows widescreen on other machines, it comes out full-screen on the APEX.
Are you setting aspect ratio to 16:9 in the video settings?I do that and my pics play proper even when i convert anamorphic pal to anamorphic ntsc .
Yes...16:9 NTSC, Non-interlace
Do retail movies play in proper ratio?Might be the authoring program you are using isnt setting the 16:9 display right.
videos/DVD won't play in widescreen in Win7
By esiebert7625 in forum Newbie / General discussionsReplies: 5Last Post: 24th Feb 2010, 23:04 -
my mwd7006 won't play my pal dvds. Firmaware?
By fnord333 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 3rd Mar 2008, 10:38 -
Vista laptop won't play my DVDs
By AlanHK in forum ComputerReplies: 1Last Post: 29th Feb 2008, 06:04 -
DVDs won't play on anything
By A Traveller in forum Software PlayingReplies: 3Last Post: 4th Jan 2008, 15:20 -
HELP! LG RH266 DVD Recorder won't play DVDs!
By Spudster2257 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 28th Dec 2007, 01:26
