Has anyone else had this problem?
Have you tried different media? Keep to branded ones to see if it is a case of bad media. What about RW both + and -, do you have problems with those? Run a cleaning disc several times to see if it alleviates the problem. Another case could be the burning software. Try a different one.
It could very well be a case of the laser failing. If the above does not work. RMA would be the next logical choice.
New burner burns SLOWLY
By will7370 in forum Newbie / General discussionsReplies: 14Last Post: 23rd Feb 2012, 21:01 -
my burner stopped burning dl only
By ninjinturdle in forum Authoring (DVD)Replies: 8Last Post: 21st Jun 2011, 13:12 -
DVD burner only burns DVD-RW now and firmware problem.
By yocahu in forum DVD & Blu-ray WritersReplies: 2Last Post: 14th Mar 2010, 21:23 -
Samsung SH-S203N SATA DVD Burner stops responding during burns?
By 1wheelken in forum DVD & Blu-ray WritersReplies: 84Last Post: 24th Aug 2009, 13:30 -
Laptop DVD Burner suddenly only burns small portion of DVD
By hydrurga in forum DVD & Blu-ray WritersReplies: 9Last Post: 13th Feb 2008, 03:39
Statistics
Newest guides
Latest tool updates
New media comments
