Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
  1. I have read in several posts that you can create an .ISO image from a CD in DVD Decrypter, but I cannot for the life of me figger out how to do it. I have also tried Record Now MAX, but can only do a Global Image .gi file. I have v3.2.1.0 of Decrypter and v4.5 of RN Max.
    I would not consider myself a noob but neither am I an expert. But I am probably missing the obvious, so please be gentle.
    Thank You in advance for the help.
  2. Hmmm you want to get or burn an .ISO image? You say burn in the title, and create an ISO from a CD in the post.....
  3. Clarification:
    I have a Data CD that I want to create an ISO image so I can store it on my Hard Drive. I have NO problem doing DVD ISO images but Decrypter will not let me do anything BUT a DVD. I have tried File | ISO I | ISO [R]ead functions, but will not allow decrypting unless there is a DVD in the source drive. I could Zip the CD, but ISO would work better for what I want to do.
  4. Subject should be:
    DVD Decrypter - How to create an .ISO image from CD......
    My bad.
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    For starters its pretty ambitious to use *DVD* Decrypter with CDs.
    I use nero, and select Image Drive as my selected burner. This then makes the image files I need. I'm sure someone else will be able to offer suggestions of other ISO creation progs, or you could do a web search on something like Create ISO software or something.
    If in doubt, Google it.
  6. DVD Decrypter CAN burn ISO or GI images to CD's.
    It CAN'T rip CD's as ISO
    BTW, whats wrong with ripping and burning GI files with RNM
    I use it often
  7. OK, DVD Decrypter won't do it.
    How do I do it in Record Now Max.
    I have tried Data .........
    Never mind....solved my own problem....
    Must use Extract and NOT GLobal Image!!!!
    ARRRGGGGHHHHHH!!!!!
    How to waste a Saturday afternoon.
    Thanks guys - problem solved
  8. To rip:
    Click DRIVE - Global Image
    To burn:
    Image Job
