I've got several avi files that play fine in Quicktime or VLC, but whenever I convert them to VCD, SVCD or DVD using ffmpegX, I get badly out of sync audio, how can this be fixed, or how should I adjust my settings to get better sync?
MakmicGuestI faced a similar problem several times, and the only way i found to solve it was:
-- reencode the the avi with "fast divX" preset (it's very fast) at same resolution and a big bitrate, not loosing too much quality.
-- transcode the reencoded divX to SVCD/DVD.
Not very elegant, but it always solved the sync issue for me...
AHA!!!!!!!
Now this makes sense to me, because THAT encoding, gives me a wealth of info I never had before, but do you know exactly what this means:
Stream #0.0: Video: msmpeg4, 320x240, 29.75 fps, 800 kb/s
Stream #0.1: Audio: mp3, 44100 Hz, stereo, 111 kb/s
the msmpeg4 is new to me, what codec is this? These are TV captures I'm working with that a PC buddy gave me, and he's....shall we say, thick, can't tell me anything about his processes....
You're right the fast divx moves pretty good, too. Even on my creakingly ancient G4 350.......wait til I get the G5!!!
AVI once converted has sync issues. Please Help!
By Marts1988 in forum Newbie / General discussionsReplies: 7Last Post: 5th Jan 2011, 01:45 -
Sync issues after muxing AVI files
By FatalX in forum EditingReplies: 0Last Post: 23rd Dec 2009, 20:33 -
Audio Sync Issues From AVI
By tyders in forum Newbie / General discussionsReplies: 5Last Post: 14th Apr 2009, 09:36 -
Weird avi audio sync issues
By afied080 in forum Newbie / General discussionsReplies: 8Last Post: 25th Oct 2007, 17:04 -
Major Problem with AVI
By thepcpitstop in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 6th Jul 2007, 11:49
Statistics
Newest guides
Latest tool updates
New media comments
