Hello all. I'm trying to learn the advanced aspects of encoding, and I was wondering if someone could tell me which (in general) is better to use between variable bitrate and constant bitrate (for movie files that average about 1 hour, 50 minutes in duration), and WHY that format is better. Also, if someone could give me a general overview of WHAT constant bitrate is and variable bitrate is, it would be greatly appreciated. If there is a link out there that tells all this info, feel free to point me to the link and I will go read up on it.
I go you one better. Do a search on the "Matrix". The information that you seek has been discussed at length many times. And, as recent as this week.Originally Posted by i am xICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W
The big problem with VBR audio is that most standalone DVD player/recorders with AVI support specifically Home Theatre DivX format require the audio to be at a CBR and the FOURCC of the video to be DX50 or DIVX to ensure no playback problems. Check out my Fixya tips here for conversion of AVI that will give you problems to those that won't.
http://www.fixya.com/support/r409677...cbr_virtualdub
If you play CBR audio AVI files on your PC you have many playback options usually a player that uses the libavcodecs like VLC Player, Mplayer and KMPlayer will play the file with no errors this can't be said for all players even the DivX player may suffer audio synch as VBR is not the standard as all will tell you even if the VBR audio is aligned with interleaves you may still have problems.
Please STOP DIG UP OLD THREADS!
Need help to set up Variable Bitrate
By spigy in forum Video ConversionReplies: 19Last Post: 16th May 2010, 13:13 -
Both constant bitrate and two press bitrate are the same,right?
By tendra in forum Video ConversionReplies: 2Last Post: 1st Nov 2009, 04:35 -
Variable bitrate Mpeg-2
By miggeth in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jun 2008, 07:58 -
I need a constant bitrate
By alexv305 in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2008, 06:38 -
Variable and Constant bitrate ??
By VEBouto in forum Newbie / General discussionsReplies: 4Last Post: 17th Oct 2007, 23:56
Statistics
Newest guides
Latest tool updates
New media comments
