I need a BIOS update. Can someone please help me find them, Really ive tried.
Heres the Info. ThanX in advance!
System
Manufacturer : Sony Corporation
Model : PCV-RX450(UC)
Version : 28400430
Serial Number : 3052972
System Chassis
Manufacturer : Chassis Manufacture
Type : Tower
Can be locked : No
Version : Chassis Version
Serial Number : Chassis Serial Number
Asset Tag : R45000000000200000000000
Boot-up State : Safe
Power State : Safe
Thermal State : Safe
Mainboard
Manufacturer : ASUSTeK Computer INC.
MP Support : No
Model : A7S-LE
Version : REV 1.xx
Serial Number : xxxxxxxxxxx
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 2
Maximum Installable Memory : 512MB
Bank 1 - DIMM 1 : DIMM Synchronous DRAM 512MB/72
Bank 2 - DIMM 2 : DIMM Synchronous DRAM 128MB/72
Chipset 1
Model : Silicon Integrated Systems (SiS) SiS730 CPU to PCI Bridge
Bus(es) : AGP PCI USB FireWire/1394 i2c/SMBus
Front Side Bus Speed : 2x 100MHz (200MHz data rate)
Maximum FSB Speed / Max Memory Speed : 2x 100MHz / 1x 100MHz
Width : 64-bit
IO Queue Depth : 3 request(s)
Logical/Chipset 1 Memory Banks
Bank 0 : 512MB SDRAM 3-3-3-6CL
Bank 1 : 128MB SDRAM 3-3-3-6CL
Width : 64-bit
Power Save Mode : No
Fixed Hole Present : No
Memory Module(s)
Memory Module 1 : PNY Electronics 512MB 16x(32Mx8) SDRAM PC133U-333-542 (CL3 up to 133MHz) (CL2 up to 100MHz)
Memory Module 2 : Hyundai Electronics 71V16635HCT8-H 00EDA0AE 128MB 8x(16Mx8) SDRAM PC133U-333-542 (CL3 up to 133MHz) (CL2 up to 100MHz)
Environment Monitor 1
Model : ITE IT8705/12 ISA
Mainboard Specific Support : No
Temperature Sensor(s)
Board Temperature : 33.0°C / 91.4°F
CPU Temperature : 37.0°C / 98.6°F
Power / Aux Temperature : 41.0°C / 105.8°F
Cooling Device(s)
Auto Fan Speed Control : No
CPU Fan Speed : 5273rpm
Voltage Sensor(s)
CPU Voltage : 1.82V
Aux Voltage : 1.76V
+3.3V Voltage : 1.63V
+5V Voltage : 4.87V
+12V Voltage : 12.29V
-12V Voltage : -8.16V
-5V Voltage : -5.81V
Standby Voltage : 5.00V
Battery Voltage : 3.81V
AGP Bus(es) on Hub 1
Version : 2.00
Speed : 4x
Fast-Writes Enabled : No
Fast-Writes Support : Yes
Side Band Enabled : No
Side Band Support : Yes
Aperture Size : 64MB
PCI Bus(es) on Hub 1
Version : 2.10
Number of Bridges : 1
PCI Bus 0 : PCI (33MHz)
Multiplier : 1/3x
LPC Hub Controller 1
Model : Silicon Integrated Systems (SiS) SiS PCI to ISA Bridge (LPC Bridge)
ACPI Power Management Enabled : Yes
Multiplier : 1/4x
Speed : 8MHz
USB Controller 1
Model : Silicon Integrated Systems (SiS) SiS5597/8 Universal Serial Bus Controller
Version : 1.00
Interface : OHCI
Channels : 3
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled : No
FireWire/1394 Controller 1
Model : Sony Corp TSB12LV26 OHCI Compliant FireWire Controller
Version : 1.00
Interface : OHCI
Enhanced Support : Yes
Channels : 64
Speed : 400MHz
System SMBus Controller 1
Model : SiS 5595 Internal SMBus
Slave Device Enabled : No
Expansion Slot(s)
PCI 1 (1h) : PCI 32-bit PME Half-Length Used (Silicon Integrated Systems (SiS) SiS PCI to ISA Bridge (LPC Bridge))
PCI 2 (2h) : PCI 32-bit PME Half-Length Used (Silicon Integrated Systems (SiS) Virtual PCI to PCI Bridge)
PCI 3 (3h) : PCI 32-bit PME Half-Length Used
AGP (4h) : PCI 32-bit PME Half-Length Available
Port Connector
PRIMARY IDE/HDD : None - ATA / None
SECONDARY IDE/HDD : None - ATA / None
FLOPPY : None - Floppy Disk / None
USB1 : USB - None / USB
USB2 : USB - None / USB
PS/2 Keybaord : Keyboard - None / PS/2
PS/2 Mouse : Mouse - None / PS/2
Parallel Port : Parallel Port ECP/EPP - None / DB-25 pin female
Serial Port 1 : Serial Port 16550 - None / DB-9 pin male
Serial Port 2 : Serial Port 16550 - None / DB-9 pin male
Joystick Port : Joystick - None / DB-15 pin female
MIDI Port : MIDI - None / DB-15 pin female
Line In Jack : Audio - None / Mini-jack
Video Port : Video - None / Mini-jack
Performance Tips
Warning 2533 : Disabled host controllers are present. Check BIOS settings.
Results 1 to 12 of 12
Thread: BIOS ~ Please HElp
you should be able to get them off ASUS's website .. www.asus.com just do a search for your motherboard. Their quick download search seams to be offline right now though.
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune
Actually this mo-bo came with my sony vaio PCV-RX450. If thats any info.
can find your board but here's the only that look close
A7S-VM
This is from www.sony.com Kinda
Drivers and updates
BIOS
If none of those work navigate from here:
http://www.ita.sel.sony.com/support/pc/pcvrx450rx460/
or here:
Then just type in the model # PCV-RX450 in the search window
One that came close? Is that good if I use it?
Better than nothing. It's the same model almost. Which might mean it for an older or newer version/moldel of your system. I'd try it.Originally Posted by gooberguy
But if it messus up, My pc wouldt even start up...
Do whatever you want, if it doesn't boot, pop the battery out and it will reset or short the jumperOriginally Posted by gooberguy
No, if the flash screws up, popping the battery out will not reset to the old BIOS.
The old BIOS is no longer there.
If this machine lets you see the BIOS string on boot, 30 characters or so across the bottom of the boot screen, when it's counting the RAM or whatever, write it down, even if it tskes a dozen resets, unless "Pause" button works.
Go to motherboardhomeworld.org, I think is the name, and enter the BIOS string. It will tell you where to go for a new BIOS, if it is in their database..
DL and flash, per their instructions.
Cheers,
George
Havet tried this yet, but it sounds like this will work so thanks. Ill post back if it works!
This may help you go to AIDA32 website and download the Enterprise System Utility run it and click on computer/summary scroll down and it will give you your BIOS info, the date of it and will give you a link to check for updates. This is how I checked and updated mine hope it will work for you. here is the link.
http://www.aida32.hu/aida32-download.php
hootie29
I tried what gmatov said but it didnt work. Because when i load up my Pc it doesnt say anything about it. Im Trying what hootie29 said right now.
BIOS version
By A Traveller in forum ComputerReplies: 2Last Post: 25th Oct 2009, 08:56 -
Q Fan in BIOS
By wingfan in forum ComputerReplies: 1Last Post: 24th Mar 2009, 12:44 -
Can't get to BIOS
By videocheez in forum ComputerReplies: 5Last Post: 31st Aug 2008, 21:23 -
ACPI in bios - on or off?
By kenmo in forum LinuxReplies: 1Last Post: 15th Apr 2008, 07:23 -
BIOS Problem
By Nitro89 in forum ComputerReplies: 13Last Post: 16th Jan 2008, 10:38
