VideoHelp.com Forum
Thread: pocket pc help
  1. just got a pocket pc and been told i can convert a dvd to play on it.
    q1, how do i do it.
    q2, is there a program to do this?.(not a demo but full and working).
    q3, is there a place like dvdhelp.com but for pocket pcs?.
    q4, if it can be done with convensonal tools what tools and how?,
    i know that i am asking a lot but i know if anyone can help then this is the place to start. thank you
    First of all, you need to know what video format does you ppc supports. I know mine and I am sure yours is same. Or find a program (for the format you wish to use) that will run on your ppc.
    Then you look for the software which will produce the format for your ppc.
    Watch it on you ppc. (I recently created a home video and tested it out)
  3. Check out Pocket MVP at http://www.corecodec.com
    This is what I use to watch Xvid encoded movies with Ogg Vorbis audio. If you want a rundown of how to encode movies for it check out this post I wrote on there forums: http://www.corecodec.com/modules.php...iewtopic&t=559
    It is a slick program and it is freeware.
    -Suntan
  4. Member Hardcoreruss's Avatar
    1. Rip with DVD decrypter in video mode
    2. Open Dr Divx
    3. Select files
    4. Set resolution to 352 X 144
    5. Bitrate for a 140 min movie will be about (stress about) 100
    6. Encode
    7. Copy to your card
    8. Worth investing in a usb 2.0 card reader/writer. Will save you hours.
    Also worth buying a larger card. I watch mine on a 256 mb sd card and the quality is dead good.
    If it's wet, drink it
    My DVD Collection
  1. Help please, easy format pocket camcorder?
    By Lilygrace in forum Newbie / General discussions
    Last Post: 23rd Aug 2010, 12:04
  2. safe few bucks from my pocket
    By mrdin2005 in forum Video Streaming
    Last Post: 20th Jul 2009, 04:26
  3. Fujitsu Siemens Pocket LOOX
    By mgowins in forum Video Conversion
    Last Post: 9th Jul 2009, 16:09
  4. Movie player for Pocket PC??
    By Cazz in forum Software Playing
    Last Post: 2nd Jul 2009, 15:39
  5. Is my Passport Pocket USB 2.0 dead?
    By htp367 in forum Computer
    Last Post: 23rd Aug 2007, 14:15
