VideoHelp.com Forum
  1. ok im trying to get small bits of dvd footage of a few movies to advertise my new website that is coming out this fall. i wanna put them all together in sort of a trailer type thing. i dont want to rip the whole movie so is it possible to only rip the part i need and convert that into an avi file?? i know the experts here can point me in the right direction. thanks guys!
  2. Its quite easy to rip by chapter, but smaller than that would need some sort of editing software.
  3. Member akbor75's Avatar
    you can use analog capture.
    as you put it on a website, that quality will be sufficient.
    Music was my first love, and it will be my last
  4. The MPEG2 version of VirtualDub or TMPGEnc will allow you to take clips from DVD videos.
    I find it easier to pull clips using DVDShrink but since you plan on using it on the web (most likely in AVI, MPG or WMV format), you would have to convert the IFO/BUP/VOB structure to a web-friendly format such as these.
  1. trying to strip audio and save video portion only
    By geminidreamer in forum Editing
    Last Post: 17th Apr 2011, 12:28
  2. How to rip dvd into small size mkv
    By mazeer in forum DVD Ripping
    Last Post: 5th Jan 2011, 15:05
  3. Replies: 1
    Last Post: 7th Aug 2008, 19:11
  4. Replies: 3
    Last Post: 2nd Mar 2008, 19:54
  5. Laptop DVD Burner suddenly only burns small portion of DVD
    By hydrurga in forum DVD & Blu-ray Writers
    Last Post: 13th Feb 2008, 03:39
