VideoHelp.com Forum
  1. Hey guys, I'm new here.. anyway.. I've wanted to purchase a desktop DVD recorder for awhile now, and I've been doing some research as far as to which model/brand I should get. I'm interested in a brand that records DVD-R's primarily. My #1 priority is quality of the tapes, I want good quality on the DVDs in 3 hour or 4 hour mode mainly (good 6 hour quality would be nice too).. I was looking at pioneer but after reading some of their reviews here, it doesn't look like I can get a good pioneer one that records with good quality.
    My second priority is a hard drive, which would be nice for editing out commericals and stuff.
    Thats really it, I would apperciate any suggestions any of you have. Thanks!
  2. Member FulciLives's Avatar
    If you want a stand alone DVD recorder that does DVD-R and includes a built-in HDD for capture/editing then you cannot go wrong with Panasonic.
    The best bang for the buck right now is the DMR-E80 which has an 80GB HDD built-in but later this year (I think sometime in May of 2004) Panasonic will be releasing even newer models and the replacement for the DMR-E80 is the DMR-E85 and it comes with a 120GB HDD built-in!
    A word of warning ... if you are a quality freak then the 2 hour mode is the best choice for a balance of content and quality (there is a 1 hour mode but even being a quality freak I realize how limiting that is time wise per disc). The 4 hour mode is OK but I surely woulnd't "push it" past that. In other words you can forget good quality at 6 hours. DVD just can't cut it there as the capacity of a single layer DVD disc is just not enough for that much content ... at least not in any remote defination of the word quality.
    - John "FulciLives" Coleman
  3. Member FulciLives's Avatar
    I forgot to mention something ...
    You might want to check out the website AVS forum
    They have a forum dedicated to stand alone DVD recorders.
    It is a great resource
  4. Originally Posted by FulciLives
    I agree with John and would even question the 4-hour mode if there's any action or flashing lights - especially difficult for encoders. That's a personal choice though and everyone's idea of what "good enough" is is bound to be different I also would recommend a Panasonic ...they're well-designed and the quality will surprise you.
  1. Advice on TV-card purchase.
    By Homercleese in forum DVB / HDTV
    Last Post: 27th Dec 2009, 16:27
  2. Advice needed in a VHS/DVD recorder purchase
    By higgins327 in forum DVD & Blu-ray Recorders
    Last Post: 14th Aug 2008, 15:44
  3. Advice on new Computer Purchase
    By wiseant in forum Computer
    Last Post: 17th May 2008, 03:56
  4. Need advice for buying a desktop DVD recorder.
    By Xandaum in forum DVD & Blu-ray Recorders
    Last Post: 24th Jul 2007, 10:16
  5. Can Anyone Recomend a DVD Recorder DeskTop with a Hard drive?
    By scustalow in forum DVD & Blu-ray Recorders
    Last Post: 24th May 2007, 07:08
