Hi all,
I've bought 3 DVD AMW V99 during the boxing day at Future Shop in
Montreal Canada and got the same problem in playing the MPEG-1 ISO files.
I usually put 10 MPEG-1 ISO files of 400MB each (352x240 29.97fps CBR
1150kps Layer 2 44100hz 224kps) on a DVD-R (Princo 1x/4x), burn as data with Stomp RecordNow Max software, then watch these MPEG-1 ISO files without problem with Norcent DP300 or Daytek P871 DVD Player.
There are some playback problem with the AMW V99 DVD Players that I
bought but here are the problems that I asked for help:
1-The MPEG-1 raw files were not played continuously. They play one file then stop, have to choose the next file to play. Norcent DP300 and Daytek P871 DVD Players play continuously this DVD-R of mpeg-1 iso files.
2-The menu button not work. Have to press stop button to get back to the 'root' disk
3-The Previous and Next buttons not jump to the previous file or to the next file on the disk as expected.
4-The AMW V99 cannot play the 7th to 10th MPEG-1 files on the DVD-R of
10 MPEG-1 of 400MB each. (So sad, we can only watch the MPEG-1 ISO files from 1st to 6th files and 7th to end with computer) or in summary, the AMW V99 can play around 400MBx6=2.4GB MPEG-1 ISO files.
Is there any patch/new firmware for AMW V99 to overcome these problems?
-The data option of Stomp RecordMax Now used to burn is UDF with Joliet-Up to 106 in length, any char.plus Joliet,plus 8+3 tree (Bridge)
-I tried also to burn the MPEG-1 raw files with Nero (DVD ISO, DVD-UDF, DVD UDF/ISO) and see the option DVD UDF/ISO allow to play the 7th file one day but still cannot play the 8th to end file.
Thanks in advance for any help.
Results 1 to 1 of 1
problem playing blu-ray iso mounted on virtual drive
By ryoaska1 in forum Authoring (Blu-ray)Replies: 10Last Post: 26th May 2011, 12:56 -
"DVD MPEG ISO" and random playing
By Disco Makberto in forum DVD & Blu-ray PlayersReplies: 4Last Post: 7th Oct 2009, 04:52 -
Problem with Audio when playing VOB dvd files
By rbrown871 in forum AudioReplies: 9Last Post: 8th Dec 2008, 09:36 -
problem playing burned .iso dvd in my dvd player
By method in forum DVD RippingReplies: 6Last Post: 5th Dec 2007, 06:12 -
Playing ISO and VOB files directly to TV
By indiraider in forum DVD & Blu-ray PlayersReplies: 3Last Post: 13th Oct 2007, 00:29
