VideoHelp.com Forum
  1. Is the media code on these discs the same as the ones made in Japan? (TYG01). I've been using tdk with no success, be it ritekg04 or non-riteks. Switched to Fuji made in Japan and used the same tools with success. Just wondering if made in Taiwan is reliable coz they're a lot cheaper in spindles of 25 at Staples Canada. Thanks.
    Nothing is as good as Fuji-branded Taiyo Yuden discs or Taiyo Yuden discs themselves.
    Generally speaking, Taiwanese-made discs are hit-and-miss quality and rarely near the quality of Taiyo Yuden.
    You'll be paying less, so I suspect you'll be getting less. Try a forum search with 'Fuji' and 'Taiwan' and I think you'll get some hits on this one.
  3. Thanks for your speedy reply.
  4. For the -R, the taiwanese made ones are Prodisc I believe. You can't rely on anyone these days.
    Blah, blah, blah
    The +R Fuji discs that I have gotten have all been RICOHJPN001 media codes. Besides the TYs, these have been very god, reliable discs.
  6. iv used tdk and they come out ok.the best iv found are memorex dvd + r
    movies do we watch them or do they watch us?
  7. Member FulciLives's Avatar
    Just to make it clear only the FUJI DVD-R discs that say MADE IN JAPAN are Taiyo Yuden discs.
    This also applies to FUJI packages of CD-R discs.
    It is my favorite media but MAXELL is now making 4x DVD-R discs that are MADE IN JAPAN and are just as good as the Taiyo Yuden 4x DVD-R discs but the MAXELL discs can be found for a lot cheaper.
    As far as USA retail stores go your best bet in price:
    BEST BUY for the FUJI MADE IN JAPAN 4x DVD-R Taiyo Yuden discs.
    WALMART for the MAXELL MADE IN JAPAN 4x DVD-R discs.
    You can also get Taiyo Yuden 4x DVD-R discs direct from RIMA.COM for around the same price as you would pay for the MAXELL DVD discs at WALMART.
    RIMA.COM also has ink-jet printable 4x DVD-R Taiyo Yuden discs although they are obviously a bit more.
    - John "FulciLives" Coleman
    Why are you guys talking media in this forum?
  1. NTSC (Taiwan) <> PAL (Germany)
    By domtw in forum Newbie / General discussions
    Last Post: 31st Mar 2011, 11:17
  2. Replies: 5
    Last Post: 7th Dec 2009, 10:20
  3. Replies: 1
    Last Post: 16th Sep 2008, 13:45
  4. Maxell and TDK made in Taiwan
    By xSimonx in forum Media
    Last Post: 15th Oct 2007, 20:58
  5. Are Verbatim's 'Made in Taiwan' discs...
    By dvdashot in forum Media
    Last Post: 8th Aug 2007, 13:55
