VideoHelp.com Forum
  1. I'm planning to buy a DVD Player that support DVI connection (upconverts to 720p and 1080i)
    I've read a few reviews of the players that support such feature, but I still can't find the answer to my question.
    Is it true that upscaling to 720P/1080i will only work on retail DVD and not copied/burned DVD?
    I don't know if that is the case, some of the post i've read seem to suggest so. Could someone please provide a detailed explanation as to why and are there any method to get around it?
    Right now I'm planning to go with LG DV7832
    http://www.2001audiovideo.com/dvds_01/DV7832.html
    Just wanted to know all the facts before purchasing the unit
    Any feedback will be appreciated, tia
  2. Член BJ_M's Avatar
    i cant tell you about that unit -- but i can about the samsung 931 which does the same thing -- i have a couple of these units...
    it all depends how they implement the digital protection .. the bravo bypasses it and the samsung doesnt ...
    in other words -- it will not work unless your video projector or plasma or hdtv rear view or hdtv crt has HDCP (high-bandwidth digital content protect)
    you should check hardware compatability -- because if the display screen doesnt have it -- you get no upsampling .. and i think the LG works the same way ....
    as for your own material -- i have been able to play it with no problems...
    there are rumours of a way to bypass HDCP -- which is a real pain for us to test different equipment .. ALL high end video projectors don't have it ...
    i have a workaround -- but its not cheap ... but allows me to use all HDTV display equipment ....
    see some more info here http://www.projectorpeople.com/tutorials/HDCP_DVI.asp
  1. Plug DVI/HDMI adapter to DVI video card?
    By Stealth3si in forum Media Center PC / MediaCenters
    Last Post: 23rd Dec 2010, 19:32
  2. Question about DVI-D & DVI connections ?
    By VEBouto in forum Computer
    Last Post: 27th Oct 2010, 08:28
  3. Quick DVD LAB Pro question
    By sterankin in forum Authoring (DVD)
    Last Post: 12th Aug 2010, 05:13
  4. TMPGEnc DVD Author - Quick Slideshow Question
    By heyjjjaded in forum Authoring (DVD)
    Last Post: 4th Mar 2008, 06:13
  5. Hi havent done much dvd burning in awhile and had quick question
    By pitten247 in forum Newbie / General discussions
    Last Post: 15th Jan 2008, 20:10
