I'm trying to take some SVCD files I've downloaded and put them into a DVD using TMPGEnc DVD Author.
So...I went ahead and did it straight, but in my set top DVD player I get no audio.
When I look at the audio settings for the disc on my player, it tells me that it's MPG audio. I'm guessing I need it to be PCM audio.
TMPGEnc won't let me do that, as near as I can tell. Hell, it won't even load the SVCD MPG file.
So, what should I be using to convert, then?
-Joe
Results 1 to 1 of 1
No sound from a PCM audio stream using DVDFab DVD to AVI file.
By loninappleton in forum AudioReplies: 8Last Post: 5th Dec 2011, 04:27 -
How to convert PCM audio track inside M2TS file
By majouz in forum Software PlayingReplies: 1Last Post: 20th Jun 2011, 14:24 -
Can't play PCM audio from MPEG made from MKV
By brianp6621 in forum AudioReplies: 10Last Post: 19th Oct 2009, 12:12 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Playing PCM audio within AVI file
By acid_burn in forum Newbie / General discussionsReplies: 1Last Post: 25th Dec 2007, 03:27
