Hello everyone,
another question...
If I have a 700 mb .avi movie and want to burn it to DVD will it make much difference (in terms of picture quality) if I choose to convert the file to 2.2 GB rather than 4.3 GB. Obviously this may mean reducing the relative bitrate by appx. 50% (compared to the 4.3 GB alternative) but I asume that this bit rate should be succiciently high to maintain most/all of the original .avi's picture quality. After all, I will be nearly quadrupling the size of the original movie.
Also, can there be any compatability issues in burning images which only take up 50% of a DVD+R.
Thanks,
Iceberg.
How do you plan to convert a 700 MB avi file to a 2.2 GB mpeg file?
(NTSC 1/2DVD = 352x480)
Using TMPEGEnc to convert the .avi to a DVD compatible .mpg file.
If you have a 7 GB avi and want to convert it to a 2.2 GB file that would be easy with TMPEGENC or any other. But if it's just a 700 MB file you'll have to put a lot of bitrate into it. Take a look at the How To section at the left.
Good Luck!
It's the length of the avi that matters, not the size. Assuming you have a typical source of 1.5 - 2 hrs, then fravel made a good suggestion to use 1/2 DVD resolution (352x480). You can get up to 4 hours on a disk with pretty reasonable quality that way, even more if you use 2-pass VBR.Originally Posted by icebergx
Using 1/2 a DVD is OK, but you could put two files on the same DVD."Art is making something out of nothing and selling it." - Frank Zappa
Virtual Dub converted files poor quality.
By stark88 in forum Video ConversionReplies: 4Last Post: 8th May 2011, 22:39 -
Capturing still images - keep quality
By CharlesH in forum CapturingReplies: 1Last Post: 6th Apr 2010, 18:39 -
converted AVI to DVD, VIDEO_TS is created, but once on DVD, movie is green
By jens.3 in forum ffmpegX general discussionReplies: 3Last Post: 18th Dec 2009, 00:43 -
converted a divx 1.1 gb. dvd was only 2.6 gb and poor quality. why is this
By sabre76 in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 3rd Jul 2009, 15:15 -
How to get best quality slideshiw from highres/quality images.
By scooter2591 in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th Apr 2009, 17:12
