I was to back up a DVD that is too big to fit on a DVD-R disc so I would like to trim the fat out of it. The movie portion is 5.1gb. If I demux a VOB from the movie I find that is has 3 ac3 components (English Dolby Surround, English 5.1 Surround, and French). I was wondering if I could demux the whole movie, then remux it with only the English 5.1 Surround ac3 component as a means to trim the size.
If so:
1) How do I determine which ac3 component file is the one I want? Is there a tool that will tell me this?
2) What tool do I use to remux them back into VOB form so I can use Sizzle to author the new disk?
I would really like to do this without converting or recompressing the video. I want to keep full quality video.
thanks,
Thread: Multiple ac3 components
But dooesn't DVD2oneX automatically recompress the video? I don't want to degrade the video.
Originally Posted by DVmadman
How can a 5.1GB video fit into DVD-R since DVD-R can hold about 4.7GB if you don't want to trim the video?
If he trims 2/3 of the audio in the movie portion, that might do the trick. And, I don't believe that DVD2oneX will upscale video, so try picking a ridiculous custom size, like 20000 MB. I don't know if that'll work though, got nothing to try it on right now. I'd like to hear your results though...
If it isn't broken, take it apart and find out why.
blog: deadsierra
my experience:
you can do it, however you will get slightly (by say 100 megs) reduced file size. No biggie though, its VERY hard to notice the difference of that from the source files
best luck. just pick what your entire VIDEO_TS file size is as your user defined size for dvd2one
Galactica is right. The two "extra" ac3 components only amount to ~200mb. Stripping them would not get me under the DVD-R limit. I had to resort to DVD2oneX afterall.
The good news is that the video still looks great even ofter recompression.
Thanks all for the input.
Trying to update ffmpeg components
By doodlebuggy in forum ffmpegX general discussionReplies: 2Last Post: 20th Jul 2011, 21:57 -
HTPC video card 1 hdmi port & multiple components
By carlos28355 in forum Media Center PC / MediaCentersReplies: 11Last Post: 30th Nov 2009, 18:30 -
Solved: Different computers, same components. Same performance?
By vid83 in forum ComputerReplies: 8Last Post: 14th Feb 2009, 19:12 -
Can not install mpeg components
By franks65 in forum ffmpegX general discussionReplies: 2Last Post: 9th Aug 2008, 09:57 -
m2v and ac3 multiple audio tracks to DVD
By gameroftheuk in forum Authoring (DVD)Replies: 7Last Post: 4th Aug 2008, 15:55
