VideoHelp.com Forum
    I try to encode the movies to SVCD with the appropriate bitrate and I use the SVCD Template (NTSC) and use all settings reccomended on this site. (First time i have had a problem) I get "An Error occurred when audio was decoded" as an error.
    The specs of the video are:
    1st video
    Video:
    576 X 320
    23 Frames per second
    Data Rate 137kbps
    Sample Size 24bit
    Compression DIVXMPG4 V3
    Audio:
    127kbps
    MPEG Layer 3
    2nd video
    Video:
    720 X 352
    Frame Rate 24 frames per second
    Data Rate 116kbps
    Sample Size 24 bit
    Compression DivX codec
    Audio
    Bit Rate 128kbps
    MPEG Layer-3
  2. I just scanned through something that says there are potential problems in MPEG Layer 3, did u try MPEG Layer 2 at all. Just wondering?
  3. Heyho,
    minimum datarate for a good VCD is 1500 !!! Not 115
    Try a Bitrate Calc !
  4. Does the datarate has anything to do with the audio error?
    I thought the datarate was default from the SVCD template. I could be wrong.
    It figures that I am so much of a geek that I didnt read the problems section at the bottom of the instructions.
    If you get no audio, out of sync or bad audio try to convert the audio to wav before converting. Use virtualdub read here how to do it.
    I used virtualdub and I am encoding now. I will let yall know if it works without problems.
    Thanks for the prompt response to my question.
  1. Premiere Pro 'Error Compiling Movie - Unknown error'
    By koberulz in forum Newbie / General discussions
    Last Post: 17th Apr 2012, 10:51
  2. megui audio encoding error
    By IPHONEHQ in forum Audio
    Last Post: 25th Dec 2011, 09:46
  3. Audio encoding error with MeGui
    By [ss]vegeta in forum Audio
    Last Post: 23rd Oct 2011, 14:51
  4. Error While Encoding Audio On VirtualDub
    By ashwin.terminator in forum Newbie / General discussions
    Last Post: 18th Oct 2009, 09:00
  5. BD-Rebuilder has Error in encoding audio
    By teedster in forum Blu-ray Ripping
    Last Post: 14th Oct 2009, 09:07
