Hi, just got my brand new NEC 2500A in a Bytecc combo external enclosure, I AM SO HAPPY! everything works perfectly.
I have tons of svcd in my pc, so IŽd like to burnŽem into a dvd, but as SVCD 1.0 NOT DVD format.
IŽve done some research, but no results. It seems that vcd easy doesnŽt handle dvd burning.
But, I was wondering, if maybe I create my compilation (consisting of many movies) with easy vcd onto an image file*, then opening this image file with a image drive, and copy the folders ("EXT", "MPEG2", "SEGMENT" AND "SVCD") of my compilation to a DVD-ROM format, will my home DVD player, recognize it as a standard svcd???
*Here is the other problem, I donŽt know if I can create NRG (nero) image files with VCDeasy to use it with Nero Image drive to copy "EXT", "MPEG2", "SEGMENT" AND "SVCD".
Is there an image drive for BIN files? just like NeroŽs image drive?
Well, if any one has achieved to burn SCVD 1.0 onto a DVD (+ or - R or + or - RW), PLEASE TELL ME HOW!!!
Thank you very much
Thread: DVD IN SVCD 1.0 FORMAT
You will need to extract the mpgs from the SVCD then use a program called SVCD2DVDMPG this will convert the audio to DVD compliant then apply a header patch all in one. Or you could convert the audio yourself then use TPMPEG to multiplex the video and audio as MPEG2 Program Stream then use DVDPatcher to change the header. There a few guides on this site somewhere just search for the tools i have mentioned.
Yes, daemon tools.Is there an image drive for BIN files? just like NeroŽs image drive?
You can't. But you can take (like RTailor suggests) a SVCD mpg and make it DVD compliant pretty easily with SVCD2DVDMPG and then author and bur as a real Video DVD.Well, if any one has achieved to burn SCVD 1.0 onto a DVD (+ or - R or + or - RW), PLEASE TELL ME HOW!!!
/Mats
You can try dvd-lab,it will author svcd and it might work on your dvd player.
Ben Johnson-I didnt take any stereos!
Yes DVDlab, great for authoring SVCD on DVD. You can get if you want a SVCD with AC3 sound.
THANK YOU VERY MUCH!!!
IŽll try these programs, talk to you later!
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 12:12 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21 -
digital cable = the new svcd format?
By mazinz in forum DVB / HDTVReplies: 38Last Post: 8th Jul 2008, 01:22
