Hi all,
I have a Sony DCR-TRV11 DV camera and I have used DVD Workshop 2.0, Ulead Video Studio 7.0, and Scenalyzer all to import and save my AVI file. Both Ulead products comvert the AVI to MPEG (single file). I've used other converters such as Canopus Procoder 1.5, TMPG, and CCE to also convert the AVI which produce separate movie and audio files. When I author the DVD and burn it to DVD, the video appears "jumpy" when the camera is in motion (panning) on my Sony C660 DVD player. When I watch it on my personal Sony DVD player, it is very smooth. Is the problem a problem with the media I'm using in the C660, or the C660 itself. The C660 is about 3 years old, not progressive scan. My TV is a normal 35" RCA, not digital. I cannot figure it out, and I'd like to know before I go out and buy another DVD player! The jumpy video is very irritating. Has anyone else experienced this? Thanks.
Thread: "Jumpy" video of Authored DVD
Reading around here I found lots of voodoo about setting the bit rate for the video properties of the project to higher then that of the source video. I don't think that's strictly the problem here. I fought with DVD Workshop 2 all weekend and here's what finally worked for me:
I believe DVD Workshop does the conversion on your mpeg when it doesn't like the properties, and I believe it's very picky. Here are the properties (as reported by DVD Workshop) which worked for me:
(This is for an NTSC, interlaced video)
MPEG-2 Video, Lower Field First
24 Bits, 720x480
29.970 Frames/Sec
VBR (max 8000 kbps)
LPCM Audio
48000 Hz, Stereo
For me, I beileve the kicker was the audio. I was editing in MediaStudio, and the default "ntsc dvd" template had mpeg audio as the default audio, changing it to LPCM did the trick.
As was mentioned, once you have a clip with the right properties in DVD Workshop, click it and make sure that in _both_ the video and audio tabs "Convert To Disc Template" is UNchecked.
Hope this helps.
i had a jumpy video when captured from dv to mpeg2.
when i captured to avi and converted to mpeg2 later it was ok.
don't know why that happened, but i was glad it worked out.Music was my first love, and it will be my last
What are Video "Profile Formats" or "Levels"?
By HanDuet in forum Newbie / General discussionsReplies: 2Last Post: 15th Mar 2011, 23:41 -
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 19:01 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 17:45 -
Need some help with "dubbing"/"muxing" video with audio
By FSSSWE in forum Newbie / General discussionsReplies: 9Last Post: 21st Jun 2008, 18:49 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 08:08
Statistics
Newest guides
Latest tool updates
New media comments
