OK..
This is a silly question, maybe dumb....BUT...
Can you record a DVD disc full of music and then play it on a CD player.
You know instead of 700meg of music you got 4.7gig of music.
Thread: Silly Question
nope -- dvd disks wil only play in a dvd player
to bad though ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
however you can do it so that it plays on DVD players......(solves the storage problems, but reduces machinery you can play it on)
search the guides...there is one for getting about 40 CD's worth of music onto one DVD.
Zworg2A clear conscience is usually the sign of a bad memory.
A concert DVD can be stream ripped by chapter to rip only the PCM/AC3 tracks. You will need to re-sample from 48000 to 44100 to be CD compatible. Then burn to a CDR like any audio disk. The audio track even on a dual layer disk is unlikely to be more than 700MB's(AC3),even a PCM track will usually fit although you need to edit toget it on one CDR or span it over two CDR's.
This is the way I rip DVD to audio CD.
Ripping 50gb Silly Question
By beric3236 in forum Blu-ray RippingReplies: 8Last Post: 16th Nov 2009, 19:30 -
Silly VideoLAN setup question
By Ensign in forum Software PlayingReplies: 5Last Post: 9th Dec 2008, 00:48 -
Silly mkv format, hd question.
By adkom in forum Newbie / General discussionsReplies: 1Last Post: 9th Oct 2008, 04:36 -
Silly question about cable modem and PC
By cim in forum ComputerReplies: 15Last Post: 7th Jul 2007, 18:15 -
Silly Question About AnyDVD
By hech54 in forum DVD RippingReplies: 3Last Post: 10th May 2007, 01:29
Statistics
Newest guides
Latest tool updates
New media comments
