VideoHelp.com Forum
  1. Hi!
    I have a lot of videoclips in vob format. Some are PAL, some are NTSC. I'd like to know what I have to do to burn them all in one dvd. Probably, I will have to de-multiplex the file and convert them all to NTSC or PAL. I think I can do that with FinalCut Pro or even ffmpegx.
    Am I doing this the right way? I want the final result to be loss-free (if possible) mpeg-2. Maybe DV files are better?
    What do you think I should do with the vobs?
  2. Do a forum search for a program called Sizzle. It takes individual VOBs and makes a VIDEO_TS folder that you can burn.
    MPEG2 Works comes with an application called DVD Converter that changes PAL VOBs to NTSC or the other way around.
  4. Member galactica's Avatar
    Agreed
    you will have to get them all into one format of your choice
    then its just importing into Sizzle and building the image to burn
    Like it was said, do a forum search or you can visit my website for instuction on sizzle
    its under SVCD to DVD tab
    keep in mind that process is .mpeg to dvd, which is what you will do when you demux those .vob's
    If you're not too busy, you could try something for me. Try adding a mix of NTSC and PAL vobs to the same project and see what happens. I'd be interested to know.
    If it isn't broken, take it apart and find out why.
    blog: deadsierra
  1. Putting multiple vobs onto 25g or 50g blu ray media
    By xobituaryx in forum Newbie / General discussions
    Last Post: 24th Jul 2010, 21:38
  2. putting vobs to dvds
    By chuchi327 in forum Authoring (DVD)
    Last Post: 23rd Oct 2009, 19:38
  3. Help putting together a DVD
    By Keano16 in forum Newbie / General discussions
    Last Post: 30th Oct 2008, 12:56
  4. Can I save videoclips from Timeline as a Collection in Windows Movie Maker?
    By Vargasvixen in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 3rd Jul 2008, 09:49
  5. Putting two DVD's into one
    By Victor Hen in forum Newbie / General discussions
    Last Post: 14th May 2007, 11:09
