VideoHelp.com Forum
  1. I would like to Burn a VCD to a DVD+R Disc. I have a DVD+RW but never used it. The VCD was Burned from Pinacle and plays in my DVD Player but won't play in my friends DVD player..So therefore I need a DVD instead of the VCD..Anyone know how this is done???Thanks..joeyshepard
    joeyshepard
  2. couple of guides (one from Baldrick, the site administrator) that should you how to do both a VCD-DVD and a conversion from VCD to DVD.
    The VCD to DVD process essentially upsamples the audio from 44.1 to the 48mhz dvd standard and it will play on most dvd players. Movie Factory 2 is the app to use.
    To do a TRUE conversion (where you will lose quality), use TMPGENC or other encoder to convert from VCD to DVD and then author the mpeg with any number of authoring apps like movie factory 2 or TMPGENC DVD Author.
  1. Help burning and playing VCD
    By NLO_Cliff in forum Authoring (VCD/SVCD)
    Last Post: 16th May 2011, 09:55
  2. VCD burning freeze
    By Douglas879 in forum Authoring (VCD/SVCD)
    Last Post: 28th Nov 2010, 15:23
  3. Help burning vcd
    By Reds in forum Authoring (VCD/SVCD)
    Last Post: 8th Feb 2008, 07:20
  4. vcd burning
    By srckaimal in forum Newbie / General discussions
    Last Post: 6th Dec 2007, 06:23
  5. Burning VCD/Svcd mpg files to dvd without encoding
    By Morb1ous in forum Video Conversion
    Last Post: 22nd Aug 2007, 16:56
