VideoHelp.com Forum
  1. Is there a less expensive way to capture/record HDTV broadcasts than buying a DVHS recorder??
    I realize that I'd have to buy a HDTV decoder/card and would need a very big hdd correct? the problem is, my home theater is situated in a separate room from my pc system.. i'm not sure how to tackle this.. Please advise. Thank you.
  2. Член BJ_M's Avatar
    1. buy a HDTV decoder/card .
    2. get a wireless HDTV transmitter/receiver (not all that expensive)
    there is a bunch of them at tigerdirect.com by grandtec ..
  3. Great.. thanks. But is there any drawback using wireless, i.e., loss in quantity or quality? And any recommendations as to which card?
  4. Член BJ_M's Avatar
    1. no idea
    2. http://www.digitalconnection.com/Pro...deo/mdp120.asp -- but ATI just did a press release they will have one also, very soon or maybe already .
  5. By the time you price out the cost of a HTPC (Home Theatre PC) along with $300 for the HDTV capture card... D-VHS starts to look price competitive.
    AVSForum has an entire section dedicated to HTPC and HDTV.
  6. Yes, you have a point.. But I'm also thinking of the price of DVHS tapes and longevity vs. storing on hdd or DVD-R. I can xfr captured HDTV content to DVD-R (with some re-encoding, no??).
    After reading a bit, I also understand that some cards encrypt the content captured and some don't.
  1. HDTV Ezcap capturing
    By GuEoRgUiEvI in forum Capturing
    Last Post: 27th Apr 2010, 13:41
  2. Capturing ESPN360 broadcasts
    By DVWannaB in forum Video Streaming
    Last Post: 2nd Oct 2009, 23:43
  3. Replies: 2
    Last Post: 20th Sep 2009, 08:59
  4. a few questions about capturing HDTV
    By deadrats in forum Capturing
    Last Post: 26th Dec 2008, 08:39
  5. Replies: 3
    Last Post: 7th Nov 2008, 07:20
