This is one of the last bits of research I need to do before finally
tackling this project. I've got (access to) a PC with a firewire port.
It's decently fast, so no worries there. Using WinXP.
What software should I use? Main (only?) concern is dropped frames.
If possible, I'd like to use something that can detect when it has had
to drop a frame, and inform me immediately, so I can start over, or
do whatever is appropriate. If this is simply impossible, then something
that can analyze the DV file and detect dropped frames that way is a
must.
Thanks in advance!
DVIO. 'Nuff said!
Hello.
Thanks! Before I make that little program my capture software of choice, may I ask what makes it a better choice than other software, like WinDV?
I use Scenalyzer Live to capture.
I started using Powervcr after I got 29gig of AVI files from a 2h. 15m. movie. I now transfer to the HDD in MPEG 2 and I'm happy with the quality. (others may not be). There again, I'm not looking for perfection.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
Capturing software
By sruddy in forum CapturingReplies: 2Last Post: 7th Feb 2011, 13:53 -
capturing software
By fabpozzi in forum CapturingReplies: 1Last Post: 23rd Oct 2009, 07:04 -
Use a software codec when capturing with an ADVC300?
By timothyd_1975 in forum CapturingReplies: 22Last Post: 15th Jun 2009, 23:06 -
What Software is out there that's really good for capturing?
By TheHour in forum CapturingReplies: 22Last Post: 28th Feb 2008, 15:38 -
best video capturing software?
By majax79 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jan 2008, 15:40
