Hi,
I typed the following text, as part of a reply to a post:
"Use this guide:
[Xurl=http://www.dvdrhelp.com/guides.php?howtoselect=4;43#303]Configuring TMPGEnc for high-quality, DVD-compliant MPEG-2[/urlX] (remember to rate it when you're done...)
...to help with your settings in TMPGEnc."
With the intention of having the words "Configuring TMPGEnc for high-quality, DVD-compliant MPEG-2" all highlighted as the link.
(Ignore the "X"'s - they're there so you can see the actual text, not the interpreted).
Nothing was disabled (i.e. BBCode, auto tool link).
And it came out like this:
"Use this guide:
Configuring TMPGEnc for high-quality, DVD-compliant MPEG-2 (remember to rate it when you're done...)
It seems that the ... BBCode can't be nested.
The workaround was to post with "Disable automatic tool link" enabled (i.e. unticked) to get the TOOL NAME in there (the second reference), then edit out the unwanted ... in the first part and re-post but with "Disable automatic tool link" disabled.
Does that make sense? Can it be fixed?
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
it can't be fixed easily.
OK. Workaround it is then... No biggy - Now that I'm aware that it happens...
Cheers.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
[url]www.youconvertit.com[/url] will convert most files
By Topp in forum Video ConversionReplies: 12Last Post: 21st Feb 2009, 17:58 -
Trouble with avidemux and [url]www.debian-multimedia.org[/url]
By Verlager in forum LinuxReplies: 24Last Post: 1st Dec 2008, 22:27 -
Hello! welcome to our website; [url]http://hot-nike.com[/url]
By Bodyslide in forum Video ConversionReplies: 0Last Post: 21st Jul 2008, 17:36 -
is it just me or has [url]http://www.rpc1.org/[/url] been awol for awhile?
By aedipuss in forum DVD & Blu-ray WritersReplies: 11Last Post: 30th Dec 2007, 23:19
Statistics
Newest guides
Latest tool updates
New media comments
