i notice all this flashing firmware is being done on PC's
does that mean it is not neccessary to flash a drive on a MAC?
I was thinking of buying the DVR-107. but if it wont burn @ 8x, then whats the use??
thanks
Thread: need to flash drives on MAC OSX?
All the flashing is done on PC's because most people own PC's
That does not been you don't need to flash your drive though. Most DVD burners have support for different media imprinted in their firmware, and with every new firmware release more media is supported. Even better: some drives can be upgraded to burn on higher speeds.
Before you purchase a drive, make sure it is MacOS compatible. Go to the support site, and check to see if the firmware can also be updated via the MacOS platform. If you cannot, either don't bother buying that specific drive, or have a PC available to do the firmware update in if you need to do so.
Most manufacturors (sadly) do not program firmware updaters for the MacOS X system..... so if you have a problem with a certain drive which can be solved by a firmware update, you'll have to unplug it from the mac, plug it in a PC and update it on there.
What is the best way to remux a mkv to dvd on mac osx?
By soundguy15 in forum Video ConversionReplies: 3Last Post: 16th Nov 2011, 16:39 -
Looking for a specific application for Mac OSX
By iwiiiiiiiiii in forum MacReplies: 6Last Post: 13th Jan 2011, 16:05 -
Simple .mov to Flash Video conversion for OSX
By pakawufs in forum MacReplies: 1Last Post: 22nd Oct 2009, 08:38 -
Install aegisub on Mac OSx
By Anicsi in forum MacReplies: 5Last Post: 11th Aug 2009, 07:26 -
DVD_RTAV, DV mode -RV, mac OSX
By anp in forum MacReplies: 2Last Post: 9th Jun 2007, 02:08
Statistics
Newest guides
Latest tool updates
New media comments
