Hi!
I bought a new DVD Burner and I installed Nero. But I got a problem, when I want to copy a VCD disk, at around 90% it stopped, it says that's there's an error. I never met that before, so I wonder if there's something wrong in my configuration.
My friend says that I need a codec, is he right? If yes, can you tell where I can dl it?
Thanks a lot!!!![]()
Thread: How to configure Nero
If you're copying a VCD, then there's nothing more to it than straight CD to CD copy. If you mean to create a Video DVD from VCD source, read here.
Simplest (and often best) way is to just extract the mpg from the VCd and author it as DVD using TMPGEnc DVD Author.
/Mats
Thank you!!!
it is possible that the VCD you are attempting to copy was the product of an "overburn'. So there is more data to copy then available on a standard cd without using the overburn option in Nero.Originally Posted by Lan Thanh
also, when you say that you get an error message....what specifically does the eroor message say?
[FFmpeg] configure with libavfilter
By Klagar in forum ProgrammingReplies: 32Last Post: 23rd Nov 2010, 07:37 -
Can't get VobSub Configure to work
By Hunding in forum SubtitleReplies: 0Last Post: 1st Jan 2010, 20:07 -
How to configure windv?
By BonnieW88 in forum CapturingReplies: 3Last Post: 13th Sep 2009, 08:30 -
Network won't re-configure
By Gritz in forum ComputerReplies: 2Last Post: 12th Jul 2008, 11:39 -
how configure nero 7 to start up on DVD choices
By zmartha in forum Software PlayingReplies: 4Last Post: 13th Aug 2007, 18:54
Statistics
Newest guides
Latest tool updates
New media comments
