Hi
What would be the best software to print a nice DVD Cover on paper with the right size and be able to insert it on a plastic DVD box ?
Thread: Print a DVD cover
I use one called Multicoverprint ....it was FREE when I found it.
WARNING.....I use A4 paper....not sure if it works an 8.5 x 11 paper....never tried it.
And it can do a cover the back and the little side with the right size ?
Does it do the top of the DVD (circle with a hole in the middle ?
Where do you download this free software ?
undercoverxp (do google search)
great free software, but u'll need 8.5x14 paper to print the full DVD cover art. 8.5x11 cuts some off the cover even with fill full page option. To work u have to have the cover art pre done or scan in. Its a printing progm only, can not creat cover tho. U can use Nero cover creator to make covers also.
Is multicoverprint and undercoverxp are the same software ?
or one the company name for the other ?
Check this link http://www.dvdrhelp.com/forum/viewto...584&highlight=
You're getting brutal, Sark. Brutal and needlessly sadistic.
----------------------------END OF LINE-----------------------------
Thank you, Master Control.
i've found this program to be real good.
http://www.mtzone.co.uk/jacketprinter.html
DVD Cover Templates !
By MLOR in forum MediaReplies: 8Last Post: 23rd Jun 2010, 04:20 -
How do I print out a DVD cover?
By orfajackson in forum Newbie / General discussionsReplies: 8Last Post: 13th May 2009, 14:33 -
DVD cover software
By Prot in forum MediaReplies: 6Last Post: 3rd May 2009, 23:38 -
dvd cover to icon
By pensioner in forum Newbie / General discussionsReplies: 1Last Post: 14th Feb 2009, 11:21 -
where to find DVD cover ?
By ktnwin in forum MediaReplies: 6Last Post: 11th May 2007, 16:28
