VideoHelp.com Forum
  1. Can someone tell me what is the difference between the two... I use both types of filters in VirtualDub. I'm also would like to know which filter should be used first (temporal or spatial) ???
    TIA
  2. The Old One SatStorm's Avatar
    My english are not good enough, but I'll try to explain to you anyway. Some other may help you better on this ofcourse:
    Spatial filters: Compare a pixel (or a part of the picture or a group of luminance/ brightness / chroma) with it neighbours and if the overall difference is high, it attemps a smoothing
    Temporal filters: They compare frames / fields on a time axis
    Personally, I use spatial filters first and temporal filters after.
  3. Well said by Satstorm. Explanations of these are in the avisynth documentation as well. I don't use spatial smoothing, it's too slow.
  4. Originally Posted by SatStorm
    SatStorm... a very simple explanation that helps me alot.... Many thanks my friend.....
    Kenmo
  1. Registry cleaner.
    By HotDamn! in forum Computer
    Last Post: 15th Jan 2010, 22:07
  2. Registry Cleaner
    By BLSAMPLES in forum Newbie / General discussions
    Last Post: 11th Oct 2009, 09:45
  3. Best Cleaner
    By Anurag in forum Newbie / General discussions
    Last Post: 7th May 2009, 11:49
  4. temporal and spatial filtering
    By snafubaby in forum Capturing
    Last Post: 6th Oct 2007, 10:23
  5. Vista 64 registry cleaner
    By mysts in forum Computer
    Last Post: 10th Sep 2007, 19:03
