Which would be better a Data TBC-100 PCI card or getting a JVC S-VHS w/built in TBC or a standalone TBC? I've read some of the postings regarding TBC. I found out there is a PCI card for pcs. I would like to know which is better to use. Is there a great difference between the 3? Does anyone have any experience in using the PCI card? Thanks in advance!![]()
The VCR's with a built in TBC does not do the same job as a full frame TBC card. If you have poor video, I would go with a stand alone TBC. I tried a JVC VCR with a TBC and it did not correct vertical sync problems, only a full frame stand alone TBC did.
New to tbc - need advice on optimizing Panasonic svhs ag1970 w/tbc
By yoda313 in forum CapturingReplies: 8Last Post: 15th Jan 2011, 09:43 -
Confused: Why a VCR with TBC if separate TBC needed anyway?
By tluxon in forum RestorationReplies: 202Last Post: 4th Aug 2010, 04:28 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 01:36 -
TBC's, TBC's, TBC's, upto my knees ........ puzzling over sync controls?
By StuR in forum RestorationReplies: 6Last Post: 22nd Nov 2007, 11:58 -
panasonic VCR tbc + external tbc - any use ?
By abbymat in forum RestorationReplies: 13Last Post: 15th Aug 2007, 08:29
Statistics
Newest guides
Latest tool updates
New media comments
