VideoHelp.com Forum
  1. How the heck can I get my cd burner to show up in VCD easy ? I have installed Nero burning rom so as to allow VCDeasy to use its aspi but still nothing - is there some sort of setting to adjust in VCDeasy top get it to work ?
    Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
  2. try downloading force aspi. if that does not work - go to cdrao - it may be set to to default driver .click on force drive and select one of the many drivers available - most common is generic raw mmm. if not keep trying to u have found the good driver.
  1. Muxman ver 1.0.3 Error?
    By kimis in forum Authoring (DVD)
    Last Post: 26th Dec 2010, 08:03
  2. what's BD-RE Ver 1.0/2.1/3.0??
    By Ripperxx in forum Authoring (Blu-ray)
    Last Post: 10th Aug 2010, 08:52
  3. BD-R (Ver. 1.1 1L), BD-RE (Ver. 2.1 1L) discs
    By mobie29 in forum Authoring (Blu-ray)
    Last Post: 13th Jun 2010, 14:57
  4. selectable subtitles
    By macuser1960 in forum ffmpegX general discussion
    Last Post: 6th Feb 2008, 21:10
  5. Installing a New ver of K-lite
    By AndreL in forum Software Playing
    Last Post: 23rd Aug 2007, 19:16
