VideoHelp.com Forum
    I burn dvd-rs in my pioneer a03 dvd burner. I use nero 5.5 the latest version. When I go to cancel the burn, it cancels but wont eject my disc. It is still lit up like it is burning. I press the eject button and it wont eject. I also ctrl alt del and cancel nero. It still wont eject after. I have to restart the computer to eject it. Any suggestions?
  2. Mod Neophyte Super Moderator redwudz's Avatar
    What OS are you using? XP-Cancel in Task Manager. W98-haven't used in quite a while.
    I am using xp. I used the task bar. I cancelled the nero in the task bar. Maybe I need to cancel an additional task I am not aware of or used the task bar wrong.
  4. Mod Neophyte Super Moderator redwudz's Avatar
    I use Nero 5 also. Just out of curiousity, I tried a cancel with some crappy CD blanks I had. I let it get about 1/3 of the way into the burn and cancelled. It took a few seconds, then cancelled. A few seconds later it ejected the disc. No problem. I didn't want to try it with a DVD. Probably what is going on is the program is caching the data and when you cancel, it still keeps that going. The drive and the program are still busy, that's why the disc won't eject. Normally you don't cancel a burn and your disc will be toasted anyway. Unless you can locate which process is still running and cancel that, reboot is probably a good solution as any.
  5. Well, when a burn process is started, the drive is "locked". It sounds like there is a communications problem between Nero and your drive where the drive isn't receiving or isn't acknowledging the "unlock" signal. This is fairly common in my experience and can perhaps be cured by updating IDE controller drivers or changing the burning software, but not all the time.
    Basically the only thing to do is fiddle around with anything having to do with the IDE subsystem or that drive in particular until you either get fed up or you fix it. Try installing or reinstalling an ASPI layer, update IDE controller drivers like I mentioned, change the drive's position on the IDE channel, try another burning program, make sure SP1 is installed, etc., etc., etc.
    Sorry I can't be of more help, but like I said, this is a pretty widespread problem. You can always just do what I do: never canel a burn job once it's started, the disc is ruined either way (unless it's -RW). 8)
  6. Member mats.hogberg's Avatar
    Agree. Specially when aborting operations. Seems to leave the SCSI layer (i think) in a state that can't be fixed by any other means than reboot.
    /Mats
  1. Panasonic DMR EZ28 Won't Eject Disc, Keeps Turning On & Off
    By Garyrajsich in forum DVD & Blu-ray Recorders
    Last Post: 11th Jun 2011, 18:19
  2. Replies: 3
    Last Post: 31st Oct 2009, 06:45
  3. Where is the Stop or Cancel Button in VOB2MPG ver. 3?
    By SuperFist in forum SVCD2DVD & VOB2MPG
    Last Post: 3rd Jun 2009, 04:27
  4. Replies: 6
    Last Post: 22nd Apr 2008, 10:27
  5. Optiarc AD5170A 1.13 Wont burn 'disc at once' any ideas?
    By surfmonkee in forum DVD & Blu-ray Writers
    Last Post: 17th Jan 2008, 10:44
