I want to drag a number of smaller mpeg files into vcd easy to create 1 vcd... is this possible? When I tried it, the vcd only shows the 1st mpeg file on my dvd player.
When I have connected the mpegs with Tmpeg software, I get the "autopadding" warning.
It would be so much simpler if VCDEasy has this capability. I notice I AM able to drag more than 1 mpeg file into the window.
Is there a trick to having the smaller files end up in 1 VCD using VCDEasy?
Results 1 to 1 of 1
Thread: Multiple mpegs into 1 VCD?
If you can't do something well, learn to enjoy doing it badly. --Ashleigh Brilliant
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
Batch hard encode multiple language srt to multiple videos
By clonius in forum SubtitleReplies: 4Last Post: 15th Jul 2010, 14:06 -
Multiple VCD to single DVD
By Ryan Kelly in forum MacReplies: 7Last Post: 5th Apr 2009, 11:15 -
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 2Last Post: 18th Oct 2008, 17:06 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 02:28
