I looked through the guides section, and there are couple of different methods for converting DVDs to Xvid. I'm looking for the best balance of speed, quality and ease of use.
Thanks in advance
autogk, click on it for guides.
i like Vidomi for DivX encoding and assume if you install
Xvid codec alongside, you will get ability to turn a sequence of vobs
into one DivX or Xvid file
I agree with Baldrick, if you're after ease of use, AutoGK is a cool tool. Vidomi is OK, but I found it could get a little unstable when I use other applications while it's running. That could just be my machine, though. 8)
I personally use the full-blown Gordian Knot, but it's a bit confusing so I would stay away just now. If you feel ready for moving onto a more advanced tool, I'd suggest Gordian Knot. You get total control.
Cobra
I use the older VIDOMI still avaialble..I should've said
I find the newer one unstable on my 2k boxes but fine on 9xx
Best, easiest method for converting DVD files into AVI, etc.
By pcq in forum Video ConversionReplies: 6Last Post: 30th Jul 2011, 13:13 -
What is best method of converting Blu-Ray to MKV?
By leejayd in forum Newbie / General discussionsReplies: 11Last Post: 12th Apr 2010, 15:46 -
Quickest method of converting avi to DVD ???
By blinky88 in forum Video ConversionReplies: 15Last Post: 10th Oct 2009, 01:09 -
Best Method of IVTC to use In Converting HDTV .mpg to xvid
By onesikgypo in forum DVB / HDTVReplies: 7Last Post: 30th Sep 2009, 00:13 -
what is the best method to convert XVID TO DVD?
By kobi_af in forum Video ConversionReplies: 8Last Post: 19th Nov 2007, 23:38
