here is my problem: i want to make a divx (.avi) from a .dv file (recorded from tv using formac studio tvr) but at the end of the process i get no audio track. someone can help me? i run ffmpegX 009 on osx 10.2.8
Thread: dv to divx (mencoder)
edoardoGuest
I see that nearly a year has elapsed since your question. I had the same problem, also recoding from a Formac. No audio. I don't think it has anything to do with the formac box because the DV file is fine.
Ruben Leon
Dept of Computer & Information Science
Strathclyde University
Scotland
I've been making DivX AVI's from .DV files for a while now with no real problems. I use the 'DivX ffmpeg' option, though I did encounter hang-ups using the 'DivX mencoder' option. Maybe you could try that option instead.
Also, make sure that 'encode audio' is checked under the Audio tab and the audio codec selected is correct and installed on your system.
TREM in Mencoder, what is it?
By RogerTango in forum Video ConversionReplies: 2Last Post: 24th Sep 2011, 09:49 -
Simple DivX: Crashes with Mencoder Error Every Time
By CobraPilot in forum DVD RippingReplies: 5Last Post: 10th Jul 2008, 19:47 -
Mencoder Question
By Maikeru-sama in forum Video ConversionReplies: 4Last Post: 23rd Dec 2007, 19:51 -
How to convert 16:9 to 4:3 using mencoder?
By sektionschef in forum Video ConversionReplies: 3Last Post: 11th Oct 2007, 14:41 -
Mencoder
By juanpedro01 in forum LinuxReplies: 2Last Post: 27th May 2007, 12:58
Statistics
Newest guides
Latest tool updates
New media comments
