  1. Multi leve menu in Pinnacle Studio.
    I selected different menu for each one so it is clear which one is which. To make it simple I will create 1 main menu and two submenu. Tell you the trought, I never needed more than 2 levels. This is just a guide that can be modified to your needs.
    1. Place edited video on timeline.
    2. Place 1st "main" menu (M1) at the beginning of timeline. 2nd (M2)right after that one and 3rd (M3) whenever second part of your DVD should start.
    Do not let PS add chapters automaticaly
    3. Oped first menu in editing mode by doubleclicking on it.
    4. Enable displaying of chapter numbers. This way it is easier to see what is happening.
    5. Click on first thumbnail picture.
    6. Click on top of the 2nd (M2) menu in time line and make sure that scrubber is on the beginning of menu. It should move there automaticaly, but if not... just click on diferent clip and click back on M2.
    7. Click on "Create chapter" button (or just press C). This will create link to 2nd menu.
    8. Now click on 2nd thumbnail in menu M1.
    9. Click on top of the 3rd (M3) menu in time line and repeat step 7.
    Now you have main menu that points to two submenus. You can see on thumbnails that they are ponting to M2 and M3.
    10. Oped 2nd menu in editing mode by doubleclicking on it and set manualy chapters like in steps 5, 6, 7, 8, 9, but this time instead of selecting menu select clips that are located after 2nd menu. Optionaly (I do this always) you can create link back to first menu by following same steps.
    11. Now we need to create return to 2nd menu after clips are finished. So kepp 2nd menu open for editing and click on 3rd menu in time line. This will move scrubber on the beggining of menu 3.
    12. But we need to add retun on the end of clips, so in preview window click on "Bacward one frame" button (or press Y).
    13. Click on set return (or press M). This will create return to menu 2.
    14. Do same in menu M3.
    And you are done....
    Optional steps are
    A. Change texts underneath buttons.
    B. In menu select option "", which will make it return back to menu after each clip.
    C. Instead of clicking on each thumbnail when you need to add next one you can use "Select next" or "previous" buttons.
    D. Change thumbnail picture in menu by selecting it in edit mode, moving scrubber to any part in any video on timeline and pressing button "Set thumbnail".
    Pedro,
    thanks for a great guide
    ktnwin - PATIENCE
    Very nice,
    But have you managed to burn a DVD which contains a workable menu made by pinnacle Studio 8?
  4. Originally Posted by Boterdijk
    Yes.
  5. Is it possible to add a soundtrack for the menu' only?
    Maybe that loops and do not restart if you choos a sub-menu!
  6. Originally Posted by SGResu
    Yes it is.
    Sound will start from the begining of the sound in sub-menu.
  1. Replies: 26
    Last Post: 4th Feb 2010, 21:24
  2. DVD Menu bug in Pinnacle Studio 11
    By P_Cherry in forum Newbie / General discussions
    Last Post: 5th Mar 2009, 14:22
  3. pinnacle video studio plus 9.4 DVD menu wont work?
    By hugecool in forum Newbie / General discussions
    Last Post: 7th Nov 2005, 19:11
  4. multilevel menu photo dvd
    By aneco1960 in forum Authoring (DVD)
    Last Post: 16th Aug 2004, 10:26
  5. Pinnacle Studio 8 Authored DVD and Menu Problem
    By jbullock in forum Authoring (DVD)
    Last Post: 24th Apr 2003, 16:14
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
