VideoHelp.com Forum
    I just bought a Sony DCR TRV33E minidv and tried to move some stuff filmed with it to my PC using USB (2). The quality was poor, with Sony Image Mixer the maximum resolution was 360x240. So, I'm going to buy a Firewire PCI-card, but...should I buy a FW800-model or is FW400 fast enough? I tried to find answer from the old posts, like here: http://www.dvdrhelp.com/forum/archive/t197925.html but I couldn't find any help. Isn't USB2 faster than FW400? -> So I should buy FW800. -> But then again, doesn't FW800 need 9-pin cables, the camera has only 4-pin connector, isn't that for max 400?
    Please help, what I should do?
    -miro-
    [/url]
    Miro,
    I have both of the cards Firewire 400 and 800 (usually 64 bit pci cards). The dv camera only uses 4 pins and it only uses the 400 mb transmission of data and this is enough for capturing digital video. In order for you to use the 800mb transmission you need to use all the 9 pins (this is usually used for faster external hard drives). There is an available cables that support 9 pins to 4 pins converter.
    Bebe
    Thank you, Bebe.
    I would have bought a FW800-card just to be sure, but if FW400 is enough I'll buy such. It costs only about 1/4 of the price of a FW800-card, which also is nice...
    -miro-
  1. Does anyone make a FIREWIRE 400/800 COMBO HUB?
    By KeepItSimple in forum Mac
    Last Post: 20th May 2011, 16:25
  2. ExpressCard / 34 slot vs Firewire 800
    By Sjogogo in forum Mac
    Last Post: 6th Dec 2010, 00:54
  3. FireWire 800 unecessary for DV editing...BUT...
    By Gromit137 in forum Newbie / General discussions
    Last Post: 22nd Dec 2008, 08:05
  4. FireWire 800 ... Worth It For Editing??
    By Gromit137 in forum Editing
    Last Post: 19th Dec 2008, 17:08
  5. need help on how to connect sony ilink to macbook on firewire 400
    By sasuke85 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 16th May 2007, 23:50
