VideoHelp.com Forum
  1. I've got a 30 minute DV piece that I've edited with Vegas and started serving to TMPGEnc for encoding to mpg2. For the second time, it'll crash at exactly the same spot at 61%. Vegas is giving me this error:
    Sonic Foundry Vegas 4.0
    Version 4.0 (Build 115)
    Exception 0xC0000005 (access violation) WRITE:0xA6BD000 IP:0x10BA001
    In Module 'vegas40k.dll' at Address 0x1000000 + 0xBA001
    Thread: ProgMan ID=0xA68 Stack=0x241F000-0x2420000
    Registers:
    EAX=00000000 CS=001b EIP=010ba001 EFLGS=00010246
    EBX=00000000 SS=0023 ESP=0241f6f8 EBP=00000002
    ECX=019a688b DS=0023 ESI=06577428 FS=003b
    EDX=066c58d0 ES=0023 EDI=0a6bd000 GS=0000
    Bytes at CS:EIP:
    010BA001: F3 AB 8B CA 83 E1 03 F3 ........
    010BA009: AA 5F 8B C3 5B C2 0C 00 ._..[...
    Stack Dump:
    0241F6F8: 0A69195C 0A540000 + 15195C
    0241F6FC: 447EDF60
    0241F700: 0119B6C9 01000000 + 19B6C9 (vegas40k.dll)
    0241F704: 02B54984 02AF0000 + 64984
    0241F708: 0A69195C 0A540000 + 15195C
    0241F70C: 019B1634 01940000 + 71634 (sfpagepeel.dll)
    0241F710: FD70A590
    0241F714: 00000000
    0241F718: 0241F9C4 02320000 + FF9C4
    0241F71C: 0A540000 0A540000 + 0
    0241F720: 00000000
    0241F724: 00000000
    0241F728: 019B1634 01940000 + 71634 (sfpagepeel.dll)
    0241F72C: 00000000
    0241F730: 0849390D 08490000 + 390D (dfscVegasOut.dll)
    0241F734: 0000AC44
    > 0241F79C: 00697661 00400000 + 297661 (vegas40.exe)
    0241F7A0: 0241F844 02320000 + FF844
    0241F7A4: 00000006
    0241F7A8: 00000001
    > 0241F7AC: 006D5E74 00400000 + 2D5E74 (vegas40.exe)
    0241FFF0: 00000000
    0241FFF4: 004E2CC0 00400000 + E2CC0 (vegas40.exe)
    0241FFF8: 006CAC28 00400000 + 2CAC28 (vegas40.exe)
    0241FFFC: 00000000
    Anybody got an idea?
  2. Banned
    How about posting that to Sony's Vegas forum?
  3. lol....I posted there and nobody seems to know what's going on.
    1) Can't frameserve from Vegas to TMPGEnc without an exception
    2) Can't frameserve from Vegas to MainConcept without an exception.
    3) Reinstalled plugin pac for frameserver
    That should rule out the encoder and frameserver as the problem...
    I'm going to re-capture the DV footage and see if it doesn't fix the problem. At this point, the problem is either the DV footage or Vegas.
    Anybody else?
  4. Член BJ_M's Avatar
    update to build 205 (4.0d) first
    then why dont you just use the built in encoder ?
  5. Член BJ_M's Avatar
    or just render to an another new avi file ..... at this point it would take less time most likely
  6. I always had problems trying to framserve from Vegas to TMPGenc Plus, even with plug n' pac. So I frameserve to VirtualDub and from there I framserve to TMPGEnc. Can be slow, and can cause audio delay if you seek trough the video while frameserving. If you have the hard drive space, just output the file from vegas a mjpeg or huufyuv, and load that into tmpgenc.
  7. I have read a number of comments Re problems frameserving with plugin pac, particularly with longer encodes. Have you tried serving video only and saving the audio separately?
  1. Frameserving from Sony Vegas into MXF format
    By 24fps in forum Video Conversion
    Last Post: 8th Feb 2012, 08:57
  2. Sony Vegas problem
    By francisco-drm in forum Authoring (DVD)
    Last Post: 18th Nov 2011, 06:16
  3. FrameServing from Vegas 9 to MeGUI
    By Kit-10 in forum Newbie / General discussions
    Last Post: 4th Dec 2009, 17:12
  4. colors shift when frameserving from Vegas
    By crisciunas in forum Video Conversion
    Last Post: 16th Oct 2009, 16:24
  5. Vegas problem
    By Tackleberry in forum Editing
    Last Post: 3rd Nov 2007, 11:28
