Hi,
Have have just converted a mono video source to DV and have edited to the contents in Premiere.
As the audio is in mono, only the left channel contains sound. Is it possible to convert this single channel to two channel sound (both Left and right)?
Thanks,
Ash![]()
Gold Wave. Copy and mix one channel to the other.
Hello.
Its even simpler than than, (IIRC) right click on the audio track and select duplicate on left (or right) channel.
It's more simple than that: I quote http://www.mediacollege.com/adobe/pr...udio/fill.html "The audio fill effects can be found in the effects window, under Audio Effects > Stereo > Fill Left / Fill Right. To apply either of these effects, select the appropriate clip in the timeline and drag the effect onto the clip (or drag the effect into the Effect Controls window)."
I doubt ash_melb has been patiently for 8 years for an answer
Welcome to the forum
Patience IS a virtue.
Hello.
Well, it's never too late.. even in the fast world of computing, audio. video, etc.. to learn
AC3 File: Audio only on left channel
By koberulz in forum AudioReplies: 10Last Post: 25th May 2011, 12:07 -
-acodec copy to 6 channel audio results in 2 channel?
By ninethirty in forum Video ConversionReplies: 1Last Post: 11th Feb 2011, 11:54 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 21:46 -
Convert single channel to double channel audio ...
By tariq_niazi in forum AudioReplies: 3Last Post: 15th Nov 2007, 16:47 -
Converting a Mono Left Channel to Double Mono Left/ Right Channel on a DVD
By socool135 in forum AudioReplies: 5Last Post: 16th Sep 2007, 00:45
