VideoHelp.com Forum
  1. Hi all
    Anyone know of any good software that can do covers for quad DVD cases.
    I've seen DVD cover print but although it is good because you can edit the size of the case you can only import pictures.This is the only bit of software so far that is able to print quad inserts perfect as far as size is concerned
    I liked Nero cover designer because you can make a fairly detailed cover but when you come to print it out because of the case size you either have to do the old trick of sticking 2 sheets of A4 together or buy a laser printer which is not gonna happen and Nero only has basic DVD case templates.
    I want something that you can edit the size of the case, in my case quad case with extra large spine and also add text and graphics to the cover as well. so a mix of Nero and DVD cover print would be good but can't find anything out there
    And its not for anything dodgy, its for the life cycle of a computer game i am involved with and i want to make a dvd cover for the DVD we have made
    Cheers for any help
  2. Член BJ_M's Avatar
  3. Член BJ_M's Avatar
    custom templates for above http://pete.mvd2.com/custom_templates.htm
    and more somewhere on the company web site ...
  4. Cheers
    I've used this software before buts its like nero, you can customise pretty much any cover but when you come to print it you have to choose from a predefined stock of labels and my quad cases are not there, so i print my cover but its too small.
    Is there a customize option in here that i'm missing so i can add my own case size. I want to print my cover on a case size of 5.10 Inches for left and right panel and 0.78 inches for the spine.
    The total cover width is 10.64 inches and the height is 7.25 inches
  5. ignore that, sorted it.
    Cheers for your help
  6. contrarian rallynavvie's Avatar
    I've always just measured it out and created my own templates in Photoshop or Illustrator. Just drag guides to where the folds/creases are so you know exactly where they're going to be. Far more customizeable, but a bit more $$$.
  1. dvd cover desing
    By ht0160 in forum Capturing
    Last Post: 26th Jan 2010, 15:54
  2. DVD cover software
    By Prot in forum Media
    Last Post: 3rd May 2009, 23:38
  3. Best paper for cover printing?
    By SilverBlade in forum Media
    Last Post: 4th Jun 2008, 21:01
  4. Different AR on IMDb and DVD-cover
    By tominator in forum Newbie / General discussions
    Last Post: 26th Mar 2008, 07:47
