VideoHelp.com Forum
  1. Ok let's say that i created a program in Visual Basic.net, how would you run that program like you run calculator on your start menu.
  2. hmm..
    Well, assuming you named the application newcalc.exe, I would just copy
    it to your start menu :P
    You would do this by just dragging the file newcalc.exe (from your explorer
    folder) to the Start button (lower left) and the rest is done by windows.
    Now, whenever you want to start YOUR newcalc version of calc, you would
    just press the Start button, and look your your app :P
    -vhelp
    You would look for the option in VB that says 'Make ????.exe' - in VB6 it's under the 'File' options - I don't know about VB.net but I imagine it should be similar.
    Once your have created an 'exe' file you can then treat it like any other windows program.
  1. Replies: 1
    Last Post: 9th Dec 2009, 23:33
  2. Best Of The Best Program Question ??
    By bludude in forum Blu-ray Ripping
    Last Post: 11th Aug 2009, 21:25
  3. Student TV Program Question
    By richrider in forum Newbie / General discussions
    Last Post: 22nd Jul 2009, 09:16
  4. Another question about best program
    By Kurgan71 in forum Video Conversion
    Last Post: 3rd Aug 2008, 06:03
  5. FAVC(program) Question.
    By cowboysroy31 in forum Newbie / General discussions
    Last Post: 5th Jun 2007, 03:20
