hey guys,
I am using TMPG DVD Author, and i was following the guides on how to make the basic menus in there. I made it successfully, burned it successfully with nero 6.3... but when I put the dvd in the player, it goes straight to the movie!
I have to physically press "top menu" on the remote for it to bring up the menu that i made.
I only have one clip on there, and I imported a custom picture for a background, and custom text. it all appears fine when i press the button
How do i make the DVD come up with the menu BEFORE it starts playing the clip?
-Syndrome
Thread: DVD menu not showing up at start
Got the same problem! *bump*
There's an option to show menu first, did you do that?
Some players get angry if there is no FIRSTPLAY sequence. This software does not allow a separate FIRSTPLAY SEQ. That could be it. Just something to keep in mind.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
In my player I have to check this or the menu will not display when I insert the disk.Originally Posted by steveryan
I had the same issue the first time when i was creating a DVD. Second time, when you come to the Menu creation screen, there is drop down on the right hand corner which gives options "Play Movie First" , "Play Menu First" or something of this sort.By default, "Play Movie First" is selected and we usually ignore this. But if you click on the drop down box and select "Play Menu First", it works like a GEM. (I am not sure if the wording are the same)
I have tested this and i have successfully done it.
Fixing DVD so it does not skip menu on start-up
By danielmak in forum MacReplies: 6Last Post: 30th Dec 2009, 02:45 -
Firefox - Start menu favorites problem
By Denvers Dawgs in forum ComputerReplies: 2Last Post: 30th Jul 2009, 00:29 -
PLEASE HELP - DVD Menu Buttons - I dont even know where to start...
By sk8_aholic in forum Authoring (DVD)Replies: 6Last Post: 10th Sep 2008, 00:40 -
Motion Menu's - Where Do I Start? In Photoshop?
By EViS in forum Authoring (DVD)Replies: 11Last Post: 21st Aug 2008, 22:35 -
Menu problem: Only highlights showing in player
By ericf in forum Authoring (DVD)Replies: 8Last Post: 9th Aug 2008, 09:24
