Hello I have a bunch of .wmv files on my computer that I want to burn on a CD and watch on my dvd player. I have made VCDs before but I cant find a program that will convert .wmv files into .mpg files or anything that will work on my dvd player.
I have tried TMPGEnc and I tell it to make a "MPG" file when its finished I right click on the video and go to properties and it says its a "mpeg" file...mpeg dont work on dvd players only mpg right?
Im so confuised...ALL I WANT TO DO IS burn some .wmv files on a cd so I can watch them on my dvd player on my TV.
Thanks a lot!!!!
You want to make VCD from wmv? You are on the right track using tmpegenc to make a mpeg-file. mpg and mpeg are the same, mpg is only the windows-way of writing mpeg, because it earlier only allowed 3 characters in the file suffix. Select the type of VCD you want to make in tmpegenc (PAL, NTSC etc.) and encode. When finished use Nero or vcdeasy to make a VCD. In Nero you have to specify that you want to make a VCD and it will make all the directories and files needed automatically.
At this moment I'm downloading 3 movies.
Each movie is broken down into about 20 some wmv videos. Size is about 35 megs each. After I finish getting these files for each movie I use InterVideo WinDVD Creator 2.
I import one movie at a time. Which is about 20 some wmv video files.
In case someone is confused ... I import all of the 20 some files at one time ... they are all processed as that one movie for that particular movie title.
I don't put all three movies in one project ... that would be a 6 hour long dvd ... each movie is about 2 HRs long.
I dont use the ... create DVD function [HQ quality is limited to 1 hour] ... I use it to create a DVD compliant mpg-2 video[HQ quality is not limited to 1 hour]. The file will be big ... 6 gigs or more.
I then use TMPGEnc DVD Author 1.5 to import the mpg-2 file and make my DVD and then DVDShrink to shrink it.
Check this post out ... should help you.
http://www.dvdrhelp.com/forum/viewto...=771894#771894
Oh ... BTW ... I cancelled one of the three movies ... it was funky ... no point in getting it. They're adult movies and the one I cancelled ... the guys were using condoms. LOL
well I could be mistaken but I do believe they are the same. I just take the e out of mpeg and stick with mpg.Originally Posted by smokedvw
Remember the song by ...
The Hotels ... Take the L out of lover and it's over.
Good song
Crap so I did have it right all along it was just saying its a .mpeg even though truely its a .mpg and will work as a VCD correct?
To play a VCD, you have to burn it as a VCD. It's a very specific structure. Nero/Record Now/ VCDEasy all understand waht a VCD is and how to burn it (burn as Video/VCD). If you used the VCD template in TMPGEnc, then you should be okay. If you 'messed with the settings' then it's probably not complient.
To Be, Or, Not To Be, That, Is The Gazorgan Plan
Burning some WMV and MKV files to play on a DVD Player
By marnisper in forum Newbie / General discussionsReplies: 4Last Post: 7th Oct 2011, 08:24 -
Cannot play ASF (WMV) files in Windows Media Player
By javaluvva in forum Software PlayingReplies: 3Last Post: 15th Jul 2010, 21:57 -
Can't play wmv files with windows media player 10
By GLE3 in forum Software PlayingReplies: 1Last Post: 2nd Sep 2009, 19:04 -
Media Player Classic won't play WMV files?
By majax79 in forum Software PlayingReplies: 8Last Post: 25th Nov 2008, 04:05 -
Basic questions - PowerPoint to WMV to connect with AVI files to make DVD
By epotereiko in forum Newbie / General discussionsReplies: 0Last Post: 20th Apr 2008, 12:56
