i downloaded an avi file and i want to be able to play it on windows media player. i downloaded virtualdub and it played the partial file fine except i couldnt fast forward or anything. WMP wont play it. is there any way i can construct a playable avi (on WMP so i can fast forward..tried avipreview and it coulnt open the partial file) file from the partial download?
Results 1 to 11 of 11
Maybe this will work:
In virtual dub, select "direct stream copy" under the "video" and "audio" menus. Then under "file" select "save as AVI...".
well i did that and it let me open the avi in WMP, but i still cant fast forward. here's the virtualdub log:
[/code]Code:[i] Starting up: VirtualDub build 18160/release [*] AVI: Opening file "C:\Program Files\Sysreset\download\xdmnx-ggwesb5.avi" [!] AVI: Index not found or damaged -- reconstructing via file scan. [!] AVI: Invalid chunk detected at 191658962. Enabling aggressive recovery mode. [!] AVI: Keyframe flag reconstruction was not specified in open options and the video stream is not a known keyframe-only type. Seeking in the video stream may be extremely slow. [*] Beginning dub operation. [*] Ending operation.
Try this program: http://www.avipreview.com/ Saw it in KaZaA .
what about divfix? Save the partial file (while ficing the header) as a new file and then playing the new file?
Well, it's beyond me now. But I would try to do a fast recompression on the video and then change the compression and/or force a certain number of key frames. I am just guessing though. Hopefully someone else can step in for you with a better answer.
In virtualdub when you click on file open and the file selection option appears look on the bottom left and check on the "Popup extended open option". You will then be able to reindex the avi. It will take a while but once it's done just save it again in direct stream mode which is quick and it will now be possible to seek in the new file.
I would try this: In the Open Video File dialog box in Virtualdub check the "ask for extended options after this dialog" box located in the left-hand corner. In the new dialog select "Re-derive keyframe flags" and click okay. You should be able to resave the file after keyframe processing and have functional seeking.
PB
Whoops. Looks like I took too long to post. Sorry about that.
PB
Yeah, in my experience, virtualdub can fix some files, but not all. I have had the most luck with a program called videofixer. Unfortunately it's not free and it's hard to find.
Also, try playing the file back with VLC (VideoLAN Client). It has support for playing incomplete files.
i tried to "rederive keyframe flags" and i got an error about 1/4 through the process. i'll have to look for that videofixer program i guess.
Make a playable file from AVI part 5 when you don't have parts 1-4?
By gumbygum in forum Software PlayingReplies: 3Last Post: 12th Aug 2011, 08:51 -
Steps to repair a partially downloaded .avi that has a missing header.
By torrentcrazy in forum User guidesReplies: 7Last Post: 27th Jul 2011, 09:25 -
no sound with newly downloaded .avi file
By JediPM in forum MacReplies: 7Last Post: 30th Dec 2008, 15:29 -
WMV file to AVI playable on DVD player (motion is uneven when I try)
By lizzy1e in forum Newbie / General discussionsReplies: 0Last Post: 29th Jun 2007, 15:13 -
AVI File Downloaded from torrent
By mps in forum Video ConversionReplies: 1Last Post: 10th Jun 2007, 10:54
