I'm adding a 160 Gig drive just for video use. vcd- dvd- dv movie transfer etc.
Do I need to partition the second drive? Not sure how to procede. Thanks
Win Home xp 1200 Athlon, 512 ddr memory
Nope
You can leave it as one giant drive. I would break it up though. I have a 120gig drive with 3 partitions, PICTURES, MP3's/music, and one for DVD ripping work space.
The new drive will have to contain some sort of partition, otherwise you will not be able to format it. Whether it is 1 big partition or 2 smaller ones is up to you. I would recommend you partition it as 1 drive partition and format using NTFS. If you try to partition and format as FAT32 w/ XP, you will be limited to a 32GB partition. NTFS does not have this limitation.
Unable to power on the PC after adding 2nd hard drive
By alegator in forum ComputerReplies: 10Last Post: 3rd Apr 2010, 12:57 -
Question about 2nd Hard drive for Video Capture??
By VEBouto in forum CapturingReplies: 8Last Post: 21st Nov 2009, 06:46 -
Vista Partition Hard Drive
By ks47 in forum ComputerReplies: 3Last Post: 3rd May 2009, 07:09 -
vista will not reconize 2nd SATA hard drive
By steve42069 in forum ComputerReplies: 3Last Post: 20th Mar 2008, 11:58 -
Modifying XP and Vista Partition Sizes on Single SATA Hard Drive
By Richkut in forum ComputerReplies: 1Last Post: 17th May 2007, 19:58
Statistics
Newest guides
Latest tool updates
New media comments
