Ok i am on the market to but a new Camcorder that allows me to record the signal from my VCR to the Camcorder.... I now some Sonys allow that but i like a suggestion on which to buy..
Currently looking at the 19, 22, and 33 from sony
I thought all did? All the ones I've seen do. The analog outputs also recieve input.
There is no such thing as "Idiot-Proof".........a good Idiot will get around that every time.
snake92069,
it's not really clear what you wanna do.
A) - record to miniDV tape, all your commercial VHS tapes ??
.......could it be because of MV ??
B) - R U looking for pass-through feature ??
C) - Just looking for casual VCR-to-DV_CAM feature ??
But, what else do you want to do ??
And, what's your goal w/ a DV_CAM ??
-vhelp
well i like to record my vhs tapes(Japan And Korean Music Videos) and my replays from my games (GT3 and HALO)... i used a sony from school once and it worked to do this but the canon i have only allows audio to be recorded
Do a search through this forum for "Pass Through". I'm also beginning to believe that if a "Sony" unit has both Composite In/Out and iLInk (firewire) it will do analog pass through. I have a TRV-740 and didn't think mine had it because it was not specifically stated in the spec's. Once i did some research and read the *&^%$#(*&% manual I found it and it works perfect. I couldn'e be happier. See some of the posts I've made to this forum.
Hope this helps"Technology",...It's what keeps us all moving forward.
Best HD camcorder that can record onto tape?
By alexh110 in forum Camcorders (DV/HDV/AVCHD)Replies: 19Last Post: 10th Oct 2011, 09:20 -
Is it a bad idea to record audio separate to a camcorder?
By OM2 in forum Camcorders (DV/HDV/AVCHD)Replies: 13Last Post: 28th Aug 2010, 17:31 -
Problem capturing mini dv audio w/ camcorder other than one used to record
By Nuzy in forum CapturingReplies: 18Last Post: 22nd Feb 2010, 05:35 -
Pause/Record on DVD recorder controlled by camcorder?
By maveni in forum DVD & Blu-ray RecordersReplies: 0Last Post: 15th Jan 2009, 10:27 -
Record 8mm Home Movies w/Digital Camcorder?
By stahlhart in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2007, 15:28
