Hi, I have an AVI file when opened in VirtualDub154 it displayed this error about sound skew:
{VirtualDub has detected an improper VBR audio encoding in the source AVI file and will rewrite the audio header with standard CBR values during processing for better compatibility. This may introduce up to 20066ms of skew from the video stream. If this is unacceptable, decompress the *entire* audio stream to an uncompressed WAV file and recompress with a constant bitrate encoder. (bitrate: 94.9 +7.2kbps)}
What's the best way to fix this sound skew? With what program?? And what are the commands/steps with this program??? Thanks.
I know that Goldwave would separate the Avi and sound. But how do I fixed the wav sound file skewed of up to 20066ms????![]()
You wont need to fix the sound if you extract it as wav as long as there is no bad frames,just proceed and encode.
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 08:15 -
fixing suffled AVI
By fred3f in forum EditingReplies: 7Last Post: 13th Jan 2010, 22:54 -
VirtualDub - Editing and Fixing Sound
By bpatters69 in forum EditingReplies: 1Last Post: 26th Oct 2009, 12:33 -
Fixing sound sync issues in a mkv file
By Psykro in forum EditingReplies: 3Last Post: 1st Aug 2008, 05:50 -
Fixing muffled sound on .avi file
By kman0199 in forum AudioReplies: 1Last Post: 7th Jun 2007, 00:40
Statistics
Newest guides
Latest tool updates
New media comments
